About to do an upgrade on the wheels/tires and need to know if 255s will work in the back. Doing either
255/35-20 OR 255/30-22
There is a 245 version of both, but much more expensive in the 22s. They are only P-Zeros
some one is using this setup:
size: 22 x 9.5"
offset: 35mm
bolt pattern: 5x114.3
tires: 255/30-22 V-rated or higher
PSI: ? Cold
so it would would probably fit since your are using 20's
http://forums.maxima.org/showthread....01#post3768901
size: 22 x 9.5"
offset: 35mm
PSI: ? Cold
Quote:
size: 22 x 9.5"
offset: 35mm
PSI: ? Cold[/url]
I have those specs, but my rim is 9 inches wide, runing a 255/30/22 tires are nitto 555..Originally Posted by PaL379
some one is using this setup:size: 22 x 9.5"
offset: 35mm
PSI: ? Cold[/url]
I hope you have better struts cause you will rub the rear if you don't.. the rear strut/spring set up is too soft to hold the body from dropping when going over bumps so it hits the tire..
I have a swaybar and coils to stop that from happening... another thing you will need to drop the front cause the gap will be atleast 2 inches wide from the tire to the fender...
255/35/20 kumho 712's stock set up. rear looks sweet but unfortunately i still have that 4x4 look up front
I'm running Nitto's 255/35-20 Z rated on all four corners. They pick up a little more road noise (cracks between concrete sections). My wife drives the car every day and never complains, so "no problems".
These are mounted on 20x8.5 TSW S-5 wheels.
I am running 355/35/20Z on mine also would post pics but im not allowed yet because im new to the forums or something. They run nice tho and I dont have rubbing problems.
Quote:
WTF? 355 or 255's?
