2003 maxima snow tires 16" or 17"???
Old Nov 16, 2005 | 09:25 AM
barristan's Avatar
I was on Tirerack.com looking for snow tires and found that I would be looking at around ~$600 for tires alone (not including shipping, install, etc).
I also noticed that if 16's would fit it would be quite a bit cheaper. I could buy some crappy rims for winter. Plus I could get narrower rims which would be better for the snow.
Would 16's fit?
Suggestions?
Old Nov 16, 2005 | 07:39 PM
Uber-Oakley's Avatar
16s would fit fine. Use the calculator that was posted as a sticky on the tire section to make sure you buy the right size of tire
http://www.miata.net/garage/tirecalc.html
You will definitely save a lot more money by going a size less.
Old Nov 17, 2005 | 09:45 AM
CanadianMoFo's Avatar
The narrower the tire the better it will work in the snow. And cheaper too! Its a win win situation. Always go as small as possible for winter. Usually the spare tire is the smallest diameter rim that will fit on the car, so check that and buy an appropriately sized tire/rim combo.
CM
Old Nov 17, 2005 | 05:35 PM
barristan's Avatar
Thanks guys!
MplsMadMan
Sep 4, 2015 02:23 PM
tothemax2003
Wheels/Tires
Sep 1, 2015 06:01 AM
District
Aug 15, 2015 08:23 PM
wingsfan24
Aug 15, 2015 07:35 PM
09maxshawn11
Aug 9, 2015 01:13 PM
