squeezed 18x10 on successfully?
Old Jan 7, 2006 | 10:10 PM
chris'smax's Avatar
Well after many days of playing w/ spacers and my coilovers i've finally got all my wheels to fit w/o rubbing issues. After getting everything set i noticed i have about +3mm between the inside of my tire to the brake line mounted along the trailing arm. Would this distance vary according to suspension height and travel? I wouldn't think so since it is a solid beam rear suspension but i could be wrong. Any opinions?
Old Jan 8, 2006 | 12:00 AM
Larrio's Avatar
The Definitive AE Master
It won't change via the rear beam, you are safe. You might want to roll the fenders slightly just for peace of mind on larger dips
Old Jan 8, 2006 | 06:12 AM
chris'smax's Avatar
Already done and done. It actually looks like my old setup stuck out further
Old Jan 8, 2006 | 12:15 PM
Larrio's Avatar
car is looking good
Old Jan 9, 2006 | 02:18 PM
BRAN808's Avatar
Volks
Chris.........I hate to be the first to say it, but it has to be said.........Where's the pics!!! So what tire size did you end up going with? Glad to see it worked out well for you.
Old Jan 9, 2006 | 03:16 PM
Larrio's Avatar
he has a thread in the 5th gen forums
Miket2006
Mar 1, 2021 03:55 AM
Kalrakam
Sep 16, 2015 12:30 PM
BrandonCause
Sep 14, 2015 10:41 PM
