Mille Miglia Evo 5 wheight?
Old Jan 23, 2006 | 07:28 PM
vsamoylov
does anybody know the weight of these roims? either a 17 by 8 or 18 by 8 or 18 by 8.5
thanks
Old Jan 23, 2006 | 10:15 PM
NmexMAX's Avatar
dot dot dot ...
IIRC 18x8 = 27lbs.
They're known to be heavy.
Old Jan 23, 2006 | 10:18 PM
Bonka's Avatar
Schnell kaputt
17x7 23lbs
19x8.5 29-30lbs (can't remember)..
Old Jan 23, 2006 | 10:27 PM
VIP Maxima
Originally Posted by Bonka
17x7 23lbs
HUH??? i dont think so. 19" EV-S are 38lbs. and the evo's are half an inch wider too.
Old Jan 23, 2006 | 10:28 PM
VQuick's Avatar
Chassis Freak
I have 17x8 Evo5s and according to TireRack, they weigh only 22.5 lb in +40mm offset, which is not bad at all for 17x8. I had the TireRack associate double check that weight since I didn't believe it and he said it was right. It's weird because they listed 17x7 (I think) with offset for a Honda Accord at 24 lbs or something.
VQuick's Avatar
Chassis Freak
The EV-S are significantly heavier than the Evos.
EDIT: THIRTY-EIGHT POUNDS holy f$ck I feel bad for your K-Sports, and your a$$! But they look very sweet.
Matt93SE
May 24, 2019 02:58 PM
Cant_Get_Ryte
Aug 28, 2015 06:41 AM
MAXSE5SPD
Aug 23, 2015 12:06 PM
dutch078
Wheels/Tires
Aug 3, 2015 06:58 PM
NJ_MAX2000
20
Nov 3, 2001 03:21 PM
