Need quick answer wheel inegra wheels fit the max.
Old Feb 7, 2006 | 05:39 PM
Maxima_Joe's Avatar
4th Gen Parts King
I was told by the seller they would fit integra type r, prelude, rsx, and nsx. He thinks the offset is +38. And knows they are 5 lug but not sure the offset. They are kose k1 15x7.
So will they fit a 95-99 maxima I'm almost sure they will but want some other opinions,
Old Feb 7, 2006 | 05:53 PM
Maxima_Joe's Avatar
4th Gen Parts King
Well lets hope they do because i own them now.
http://cgi.ebay.com/ebaymotors/3-JDM...QQcmdZViewItem
Old Feb 7, 2006 | 08:32 PM
Nissan 6's Avatar
jdm y0!!!!1
Old Feb 7, 2006 | 08:49 PM
98MaXeDouT's Avatar
doubt its the same bolt pattern (google?). FYI I hope you know you just bought 3 wheels, you may know, but you never know around here.
Old Feb 7, 2006 | 09:00 PM
Maxima_Joe's Avatar
4th Gen Parts King
yes i did google.From my research the maxima and integra should both be 5x114.3. I just wanted to be sure.
What i didn't buy 4 wheels? Thats some gay ****. How was i suppose to know he was only selling three?
Of course i know it's only three wheels.The wheels have been discontinued and i really only need two since these will be my drag wheels for slicks. I havn't decided if i'm going to buy a fourth or sell the third one yet.
Old Feb 7, 2006 | 11:14 PM
Nealoc187's Avatar
SLOW
Yes integra type R wheels have the same bolt pattern as the max. They will fit.
Old Feb 7, 2006 | 11:20 PM
Maxima_Joe's Avatar
4th Gen Parts King
Thanks neal. Now lets hope i can find a fourth.
Old Feb 8, 2006 | 12:24 AM
Donald199's Avatar
Tried some RSX-S rims and they do NOT fit
bolt pattern are the same and all but the hole in the center of the rim are too small to fit over the hole on the hub(the part where the axle nut goes).
It will fit if i grind off like 2mm all around the hole but those are not my rims
Old Feb 10, 2006 | 07:52 PM
irish44j's Avatar
retired moderator
this is known as the "hub bore", for future reference.
Grinding the hub bore is a no-no, unless you get it done PROFESSIONALLY by a machine shop who can do it right. Remember, the hub of the wheel supports alot of the weight of the car along with the lugs in relation to the wheels. If you were to "grind off" unevenly (even by a little bit) it could end up in:
1. unbalanced wheels
2. messed up hub
3. warped wheels and/or rotors
and other bad things.
buy wheels that fit your car correctly, don't try to alter wheels to fit, IMO.
Maxima_Joe
Nov 25, 2015 08:19 AM
Maxima_Joe
Oct 15, 2015 08:01 PM
soloist3
29
Sep 1, 2015 03:47 PM
Cant_Get_Ryte
Aug 28, 2015 06:41 AM
twotonezed
Aug 16, 2015 11:41 AM
