I noticed a few 5th gen owners had axis hiro's
Old Feb 18, 2006 | 06:30 AM
amimaxima
I was wondering what size rims they have and what size tires they are using.
I wanted to get a set of 19 inch axis hiros they are 8.5 wide and 9.5 wide I wanted to know if they would fit on a 5th gen
Old Feb 18, 2006 | 07:21 AM
KCMC582's Avatar
i think all of us have 19x8.5. 9.5 would be fine for the rear but would not fit on the front, and a staggered setup doesnt really make sense for our cars.
Old Feb 18, 2006 | 12:12 PM
Nathan's Avatar
I have 19x8.5" front & rear with 245/40's (35mm offset). Next time I'll go with 245/35's though for a more oem size.
You could use 255's or even 275's if you go 9.5" in the rear. Just make sure you get a higher offset for the 9.5" rears.
9.5" rears would look nice but you're just adding extra weight and its sort of pointless on a fwd car.
Old Feb 18, 2006 | 12:47 PM
steven88's Avatar
Need A Light?
nathan - what kind of drop are you on? 245/40 seems real thick for a 19....any problems with rubbing?
Old Feb 18, 2006 | 01:23 PM
Nathan's Avatar
I'm pretty low during the summer on ksports. Check out the 1st page for how it looks.
At that drop, I only rub the rears slightly over big bumps. I may cut off that part on the rear fender that I've seen other do, but we'll see.
CRizz
41
Jun 7, 2021 05:42 AM
Finkle
Sep 27, 2015 09:53 PM
Cant_Get_Ryte
Aug 28, 2015 06:41 AM
jerrod99_se-l
Aug 24, 2015 10:24 AM
maxinout93
Aug 20, 2015 02:17 AM
