how wide rims for 255-45-17??
Old Apr 6, 2006 | 09:27 PM
jvelos3's Avatar
so...how wide would the rims have to be to fit 255-45-17 tires??
Old Apr 7, 2006 | 06:36 AM
6SpeedTA95's Avatar
I would think at least 7.5 inches and really an 8 inch rim for a good fit.
Old Apr 7, 2006 | 07:40 AM
Ammi's Avatar
350 Detroit Muscle
8.5 or 9. Definitely not 7.5
Old Apr 7, 2006 | 07:42 AM
6SpeedTA95's Avatar
A 9? I've got 9s on my TA and 275's are about right and I could easily go to 295 on a 9 inch wheel....
Old Apr 7, 2006 | 08:26 AM
White Shadow's Avatar
Still chugging along...
Rear 350Z rims are 8" and have 235/50/17 tires. I would think 9".
Old Apr 7, 2006 | 08:40 AM
CCS2k1Max's Avatar
255/45R17s are spec'd for 8.0-9.5 inch wide rims. That said, I'd stay on the lower end but I'm betting it my still rub on a 4th gen.
Shadow, those are 50 series rims. You can put 255/65R17 tire in a 7 inch wheel and still be within specs. It depends on the aspect ratio.
Old Apr 10, 2006 | 06:01 PM
z32drifter's Avatar
9" wheel is min for 275/40 so that's the largest tire you should run on a 9.
<think about it a 275 is almost 11" wide>
I run 255/40s on 17x8.5 and 17x9 (track)
Old Apr 11, 2006 | 01:43 PM
vsamoylov
thats more like it.
Old Apr 12, 2006 | 04:50 PM
mugenmtx3
need your help for rims sizes
Hi' just wondering if you can help me up for my wheels, i have a 96 maxima with koni's front 1.75 eiback spring and agx for rear with 1.5 eiback spring,im thinking to go 19's with those like deep disk rims can you email what is the best rims that i can get and what sizes is good that will not rub on fenders both front and rear
Thanks a lot
Old Apr 12, 2006 | 05:10 PM
Ammi's Avatar
350 Detroit Muscle
19x8.5 with 245/35/19s
Old Mar 17, 2010 | 02:01 PM
dnarh1017's Avatar
What size tires am I suppose to use on my 4th gen.
Im trying to put some 20in rims on this summer
Old Mar 17, 2010 | 06:00 PM
Fast1one's Avatar
Old Mar 23, 2010 | 03:58 PM
z32drifter's Avatar
20s on a 4th gen....
These are approved with a 245/30 tire, you will want a spacer for flushness in the rear.
http://www.tirerack.com/wheels/Wheel...ll&sort=Weight
all other chrome 50lb bling master "dubs" are denied, don't even go there
Old Mar 31, 2010 | 10:32 PM
jimdandy02's Avatar
Bump I was wondering the same thing...
Old Apr 8, 2010 | 01:51 PM
2slow's Avatar
↨↨↨↨↨↨These↨↨↨↨↨↨
My rule of thumb for street tires: keep the rim width within one inch of the section width. That a rule of thumb, a.k.a. a general guide, not an absolute requirement.
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
Fbana41
Aug 29, 2016 12:18 PM
Luigi623
Sep 21, 2015 01:42 PM
mikeymouse1995
Sep 18, 2015 06:42 AM
0m3nc0w
Sep 11, 2015 05:21 PM
