95 max Tire SIze Question
Old May 5, 2006 | 08:25 AM
wilson's Avatar
Ive been running 215/50/17's on my 17inch BSA 7 inch wide rim. Now i sent my dad to get me some tires (maybe a mistake) well he bought 2 new 225/55/17 will i have any issues, will these fit on the front without rubbing? Or even on the back of the car.
Thanks for the replies.
Old May 5, 2006 | 09:57 AM
DrKlop's Avatar
Driving is the next best thing
I don't think they will rub if you are not lowered, but it is still possible. If you are lowered, they will most likely rub.
Your speedometer will be off by 5% if you install them on the front, and your car might feel a bit slower with those (regardless where you put them, front/back.)
If it's possible, you are much better off returning those IMO.
Old May 5, 2006 | 10:51 AM
wilson's Avatar
thanks alot for the reply, I am lowered on sprints/hp's, so rubbin would probably be an issue. Hes going to try and return them. Only reason why i didnt go get them b/c im stuck at work here on the computer.
Old May 5, 2006 | 12:58 PM
wilson's Avatar
thanks DrKlop, they took the tires back and exchanged them for some 215/50/17s. What tire size is recommended for a 17x7 rim? 215/50's are what the tire shop recommended when i purchased my rims a few years back
Old May 5, 2006 | 04:08 PM
DrKlop's Avatar
It is always recommended to keep outer wheel diameter stock. Regarding the thread width, it's usually anywhere between 205 - 225. To find out for sure you can go to manufacturer's website, where it will tell you how wide the rim has to be for every tire size.
ah2002
Mar 9, 2016 01:42 PM
NissLover
Aug 22, 2015 10:26 AM
maximaham
Aug 20, 2015 10:23 AM
