need some meaurement regarding 225 40 18
Old Jun 6, 2006 | 01:58 PM
kajeno's Avatar
inflated at 32 psi plus. Can someone measure the diameter on their front tires? To measure I would put something flat on top of the tire and measure from the ground up. I need this to isolated the effect of tire bowing on a smaller rim size tire like 215 55 16 compare to going plus size. Thanks.
Old Jun 6, 2006 | 05:00 PM
MyBlue02's Avatar
not sure exactly what your looking for...the side wall? or the over all?...cause the stick for the calculator shoud give you a good size (all tire brands are a little different though)
Old Jun 6, 2006 | 06:29 PM
kajeno's Avatar
I want the diameter of the whole tire (outside edges) from the ground to the top.
Old Jun 9, 2006 | 06:53 AM
kajeno's Avatar
Can someone go out and take those measurements for me? You can also give me measurement for 235 40 18. Thx.
Old Jun 9, 2006 | 09:22 AM
86maxima96's Avatar
I Broke OT
go here: http://www.miata.net/garage/tirecalc.html
Old Jun 9, 2006 | 10:56 AM
DrKlop's Avatar
Driving is the next best thing
You guys just don't understand what he wants...
he want someone who has 18" wheels measure the outer diameter of the ACTUAL tire inflated at 32psi. (not what it's supposed to be but what it really is)
Old Jun 9, 2006 | 12:26 PM
kajeno's Avatar
Thank you!
That is exactly what I want.
Old Jun 9, 2006 | 04:05 PM
86maxima96's Avatar
I Broke OT
why do you need such a precise measurement? it still won't even be that reliable as someone may have uneven treadwear, no wear, or bald tires. that could be a difference of 1-2cm.
Old Jun 9, 2006 | 04:16 PM
kajeno's Avatar
I explain in my first post why I need the measurement
Can someone just give me measurement and the state of the tires.
JAY25
Nov 4, 2001 10:23 AM
ericdwong
Oct 29, 2001 01:56 PM
flyry110
Jun 18, 2001 08:16 AM
DaBoxSE
May 30, 2001 01:29 PM
Newman
May 29, 2001 12:32 PM
