Hub Diameter for hub centering rings
Old Jun 14, 2006 | 01:53 PM
CanadianMoFo's Avatar
I asked in the wheels section and got no answer.
I need to get some hub centric spacers for some aftermarket steel rims. Does anyone know what size the 6th gen hub is?
CM
Old Jun 14, 2006 | 01:59 PM
Jeff92se's Avatar
I'm needing a caw
Nissan is typicall 66.1mm. I hope your wheels you are getting aren't really steel. If they are, most likely a hub ring wont fit
Old Jun 14, 2006 | 02:15 PM
Thanks!!
Hells yes they are steel! Real men roll on 17's yo. Come on dawg, give up the mad phat dope bomb shizz props for the steelies.
They are el cheapo steel rims for winter use only. Just hoping to get some hub rings to help center them if at all possible.
CM
Old Jun 14, 2006 | 03:19 PM
Coolhand_fm's Avatar
Go to http://www.1010tire.com/ and ask there tech support about what size rings you need they have a large slection of rings. I got my 17in steel winter rims and tires from them and they set me up with the right size rings and wheel nuts for free.
Old Jun 14, 2006 | 05:12 PM
MAXDOUT04's Avatar
* THIS SPACE FOR RENT *
66.1 mm is correct
Old Jun 15, 2006 | 08:06 AM
PENROSE2006's Avatar
http://www.discounttire.com they have them, they also have them on ebay.
If you bought the wheels new, the place you bought them from should have the rings. The place I got my wheels from sent me the rings free.
gigabyte
Jan 6, 2017 06:05 PM
Andy29
Sep 29, 2015 05:32 AM
Pied
Sep 26, 2015 03:29 PM
