About to make a long trip..what psi?
Old Jul 8, 2006 | 10:17 PM
OutMaxxed's Avatar
Hey guys im leaving to tenn. from jersey on monday. i will have 3 MAYBE a fourth person and a full trunk of stuff. What do u think is the recommended psi to run front and back? If memory serves me right.. stock is 32 psi. Im on 235/40/18 Kuhmo Ecsta 712's. Is more better in this case?
I recently had a tire hot patched and with the tire OFF the car the psi was about 40. With the tire on the car it was about 33psi. This was a rear tire. CAn someone explain this? Wouldnt the pressure be higher with the weight of the car on it?
Old Jul 9, 2006 | 12:46 PM
MDeezy's Avatar
for road trips I always up the psi to around 36, maybe 37 in the back for you. Is the max for your tires 44psi?
Old Jul 9, 2006 | 02:37 PM
DrKlop's Avatar
Driving is the next best thing
Higher pressure always results in better fuel economy. So the more the better, as long as you don't exceed maximum PSI rating (well, just in case keep it like 4 -5 psi below max) and your passengers can stand the ride.
Old Jul 9, 2006 | 02:41 PM
DrKlop's Avatar
For some reason I always thought that measuring tire pressure on or off the car does not make any difference...
Old Jul 9, 2006 | 03:04 PM
nismology's Avatar
+1 It doesn't.
Old Jul 10, 2006 | 03:23 AM
Ammi's Avatar
350 Detroit Muscle
I just leave it at 37psi all the time
matts95max
Apr 23, 2025 10:44 AM
mvm062
Nov 30, 2020 09:00 AM
captchaos
Mar 15, 2016 12:18 PM
videomano
Sep 8, 2015 03:28 PM
Maxima30
Sep 7, 2015 06:13 PM
