OZ Wheels and Tires from IS300 (48 offset with 215/40-18).
Old Jul 28, 2006 | 08:50 AM
2kSC's Avatar
The cambo wanted was 235/40/18 with 35 offset but these are 215/40/18 with 48 offset.
Will these fit?
How will it look? I think it should be close to stock but I am not sure...
Anybody have a 48 offset? If so, what tire are you runnig?
Old Jul 28, 2006 | 04:35 PM
z32drifter's Avatar
Toyotas center hub bore is smaller than Nissan, the center of the wheel would have to be machined to fit. I doubt the cost would be worth it.
Old Aug 5, 2006 | 05:57 AM
arthur glazier's Avatar
I have a set of ssr tires/rims that cam off a lexas is300 there 18x8.5 im not sure of the offset but they fit fine. the tire size was also 215 40 18 but i just drove on them untill it was time to change the tires then i went to a 235 40 18.and no problom rubing
Old Aug 19, 2006 | 01:11 PM
showoff's Avatar
I have Superleggera 18x8 45ET...245/40/18
The front are bang on, but the rears could use about 15mm to 20mm spacer.
215 is kinda narrow for a max, you want a wide footprint. I'd wait for something better. Look for 18x8 30-35mm offset
alahjahwan09
18
Sep 21, 2015 09:12 PM
Y2kMaxima
Wheels/Tires
Sep 14, 2015 10:56 PM
I<3 A32's
Sep 10, 2015 11:07 AM
dcam0326
Sep 8, 2015 11:02 PM
jfl330
Sep 4, 2015 01:44 PM
