I need new tires
Old Sep 1, 2006 | 05:10 AM
BlackFlux's Avatar
I need new tires
Ok here is the deal. I need to get new tires for my 01-SE-45K. I need tires so bad that when I come off an exit my cars slides (in the rain) out into the road. With that said I have been looking into OE tires (Bridgestone Potenza RE92). That’s about $150 per tire.
So me being the type of person that I am I started looking into some wheel and tire packages (wheelmax.com) and turns out that I can get wheels and tires for the price of some new tires.
Does anyone have any suggestions?
Old Sep 1, 2006 | 08:27 AM
limsandy's Avatar
The Potenza RE92 is crap, so don't even bother purchasing new ones. With that said, any tires in OEM size should not cost more than $150 installed. Edgeracing.com has good prices on 225/50/17 tires. The Hankook Ventus Hrii H405 is just okay if you're on a budget, but if you can afford it, I'd recommend the Toyo Proxes 4.
Old Sep 1, 2006 | 09:24 AM
BlackFlux's Avatar
"With that said, any tires in OEM size should not cost more than $150 installed." You mean $150 per tire?
Old Sep 1, 2006 | 09:31 AM
limsandy's Avatar
Yes, I meant per tire.... thanks for being a ****
Old Sep 1, 2006 | 01:29 PM
boondoxmax's Avatar
The only positive that the OEM bridgestones had was the stiff sidewall. There are a lot of better tires out there then the potenzas, but very few have the sidewall stiffness of the potenza. I've heard the poxes 4 are noisy so I stayed away from them. I have yet to decide on a tire yet.
Old Sep 3, 2006 | 11:14 AM
Tone8969's Avatar
yokohama avids hereon the 03 we have, major improvement over the oem potenzas, discount had them for under $500 out the door.
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
Garrettz459
Sep 28, 2015 02:50 PM
