225/45/17 winters?
Old Oct 8, 2006 | 10:49 PM
wade's Avatar
225/45/17 winters?
i read the FAQ for the 2002 Maxima SE 17" stock 17 X 7 info and it said that the : 225/45/17 are okay to run on the stock rims..
My question is whether or not it is a good idea to get this size as winter tires or is it better to get the regular : 225/50r17 or try and find something wider?
also if the tread is rated : 9/32 how many more seasons of tread does it have left?
thanks
Old Oct 11, 2006 | 06:35 AM
6SpeedTA95's Avatar
9/32 is an almost new tire you should have plenty of life left in those tires.
Old Oct 11, 2006 | 07:26 AM
CCS2k1Max's Avatar
FYI, my winters were 13/32nds new. 9/32nds probably have seen a couple of seasons. I say two more winters is what you can expect before they taper off.
Old Nov 3, 2006 | 02:47 PM
MaxSE03's Avatar
A wide, low profile or large tire has to "plow" a wide path through snow which causes more resistance. The narrower the tire, the easier you can get through snow.
Old Nov 17, 2006 | 06:41 AM
JohnWEngle's Avatar
For winter tires, I'd opt for the 225/50-R17 size over the 225/45-R17. The bigger sidewall will be a bit more compliant, which is generally accepted as being better in the snow.
mclasser
22
Nov 12, 2020 01:58 PM
240tomax
Tires and Wheels
Feb 10, 2016 11:01 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
Serotta33
Sep 17, 2015 12:14 PM
