Can this work...
Old Oct 10, 2006 | 06:53 AM
Killercam2's Avatar
Can this work...
I am going for a staggered look for my 2000 Max SE. I am looking to put Rear - 275/30/20 in tires with a 37mm offset. Is this possible?
Old Oct 10, 2006 | 11:29 AM
limsandy's Avatar
Short answer: No.
Old Oct 10, 2006 | 03:37 PM
Killercam2's Avatar
What is largest tire size that can fit the rear of a MAX
Old Oct 10, 2006 | 06:55 PM
limsandy's Avatar
Originally Posted by limsandy
Short answer: No.
I'm sorry... let me take that back. It really depends if you're lowered or not. If you're stock, you probably might get away with it. But if you're lowered, the wheels and tires will fit into the fender well, but you'd be rubbing all over the places..... I would imagine.
Old Oct 10, 2006 | 08:47 PM
Killercam2's Avatar
Well, in that case. I am drop now and I currently have rubbing with my 350 Z rims 18"s. I had to roll my fender for a solution to my problem. I was thinking that to offset would make a difference? I am not educated about what offset can work and what can't
tnewbs
Aug 28, 2015 10:15 AM
criminalslang810
Aug 16, 2015 08:12 AM
hoey
Aug 2, 2001 10:38 AM
psing23
Jun 26, 2001 07:46 AM
DooBall
May 18, 2001 08:04 PM
