How wide can I go?
Old Oct 15, 2006 | 08:38 AM
SMOKIN'MAX's Avatar
Stang-seeking Max Missile
How wide can I go?
I have a Gen 6 and really want to improve handling and stance(lower&wider) with a new wheel/tire pkg.. I've used all the calculators here but want realistic feedback from someone who's tried this:
18X9's w/255/45 or 275/40.
Should I get a lower offset in the rear (20mm) and 35 front or same all around. Will either work w/o rubbing issues? I want a nice low, wide stance and don't mind the tires sticking out a bit beyond flush.
Also, I'm not currently dropped, but will be getting Progress or Eibachs to go w/ the new setup.
Any feedback will be much appreciated. Thanks in advance.
Rich
Old Oct 15, 2006 | 10:22 AM
Ammi's Avatar
350 Detroit Muscle
I doubt you can run 18x9 w/ 20mm offset on the front so unless you don't mind rotating your tires, go staggered
Old Oct 15, 2006 | 10:43 AM
SMOKIN'MAX's Avatar
thanks for the reply Ammi- would you recommend 18X8.5 35 offset w/255/45?
Old Oct 15, 2006 | 02:57 PM
Ammi's Avatar
350 Detroit Muscle
yea that would work just fine but 18s little small for 05 Max. See if you can get 19s.
Old Oct 16, 2006 | 02:16 AM
limsandy's Avatar
Are you going for looks or handling performance?
If you're going for looks, I'd recommend 19" or 20" staggered.
If you're going for performance, get 18x8.5 and 245/45/18 all-around.
Old Oct 18, 2006 | 08:27 AM
SMOKIN'MAX's Avatar
Yes, I'm going for performance. If I had RWD, I'd be all over the staggered choice. On the Max, though, I want the widest tire I can have up front. On a 18X9" rim, can I go 275/40 problem free w/ Eibachs? And, should I have different offsets on F/R? A little more help here would be greatly appreciated as I'm looking to buy pretty soon.
Thanks,
Rich
Old Oct 18, 2006 | 08:05 PM
Ammi's Avatar
350 Detroit Muscle
I believe you'll have problems with 275s up front
Old Oct 20, 2006 | 02:30 AM
limsandy's Avatar
You can go 18x9 all around and still keep 245/45/18, since you're going for performance.
Old Oct 23, 2006 | 12:26 PM
xoomer.com's Avatar
I Donate! Why Don't You?
I saw a guy with 275/35/19 this past weekend but he wasn't dropped.
Old Oct 25, 2006 | 09:32 AM
AnDyMaN's Avatar
what other tire size fits in the front? could a 265 40 18 fit in the front? btw, the rears cand handle bigger/wider than the front right?
02PearlSE
Oct 7, 2015 02:12 AM
DBear
Sep 14, 2015 08:33 PM
jhontelj
Aug 17, 2015 04:07 AM
ericdwong
Feb 22, 2001 10:40 PM
ericdwong
Feb 21, 2001 09:16 AM
