Input Specific to Snows
Old Nov 2, 2006 | 07:36 AM
Skier's Avatar
Searched and found lots of performance tire comparisons, but I am looking for comments specific to snow tires. I will be running either Nokian WHR (all season), Nokian RSi's (snow specific) or Nokian H4's (studded). I ran the Nokian WRH last 3 seasons. Traction was "OK", handling was good, and the tires were quiet, but I found tire life poor (almost worn out after 2 winters). I hear the H4 studded are "great" for traction, but a softer sidewall construction reduces handling and crisp lane changes when the pavement is clear and dry.
Any input from those running one of these tires is much appreciated. If you have other suggestions than Nokians and have had good luck, please advise as well.
Thanks All
Old Nov 2, 2006 | 08:52 AM
upstatemax's Avatar
Nokian Hakkapeliitta NRW's...
Best snow tire I have EVER used... ONLY use them in the winter since they are a snow tire. Summer heats will chew them up really fast.
Old Nov 2, 2006 | 09:06 AM
Skier's Avatar
Are they studded?
How is the noise level?
Old Nov 2, 2006 | 12:33 PM
irish44j's Avatar
retired moderator
where do you live?
I use Blizzak LM22s from November to February. Great in the dry, unstoppable in the snow and ice.
Old Nov 3, 2006 | 06:28 AM
upstatemax's Avatar
Originally Posted by Skier
Are they studded?
They are not studded, the noise level is ok (hey they are snows...). But, as I said before, they perform really, really well. They saved my a$$ several times.
Old Nov 7, 2006 | 09:18 AM
Skier's Avatar
Those NRW's are the tires the WRH replaced. I was not impressed by the tread life of the WRH and the traction was quite good but could be better. It is also classified by Nokian as an all season radial, not specifically a snow tire. I just ordered the hakk 4 studded ($217 ea mounted & balanced where I go). They will be mounted in 2 weeks. I read that these give up some handling, but can not be beat for traction in snow and espeacially on the black ice that forms here in NH about every time snow first hits the pavement. I will post a report on noise and handling on dry roads, then after our first snow event I will post another report.
James92SE
142
Jan 2, 2024 09:23 AM
bigdogsteve
Jan 31, 2018 04:18 PM
Robert Schneeweis
Jan 11, 2017 06:47 PM
gigabyte
Jan 6, 2017 06:05 PM
thatcollegestudent
18
Oct 5, 2015 02:29 PM
