Bolt pattern question
Old Dec 21, 2006 | 07:16 PM
JaKillz2's Avatar
I looked in the manual and downloaded hanes but somehow avoided this, but on the 2000 maxima se, what is the bolt pattern? I found some descent 17in g35 rims and they have the pattern 5 x 114.3 and are about 400$, there is the same set below them only they have the pattern 5 x 4.5 and are 900$. Why the price difference? And what pattern should I look for? It said they were the same but I just wanted to make sure.
Old Dec 21, 2006 | 07:41 PM
RA030726's Avatar
I'm nutty for Nissans
Technicly both patterns are the same, one is metric the other english. As for the price, chances are the cheaper ones are knock offs. They exist all over ebay. All 5 lug nissans are 5x114.3mm with a hub bore of about 66.1mm or so.
Old Dec 22, 2006 | 06:37 AM
JaKillz2's Avatar
K, Thanks for the info
Old Dec 22, 2006 | 07:33 AM
NmexMAX's Avatar
dot dot dot ...
25.4mm = 1".
114.3/25.4 = 4.5
The Frye
Sep 2, 2021 11:03 AM
ef9
Sep 29, 2015 11:29 PM
mpbclutch33
Sep 21, 2015 01:54 PM
bumpypickle
Sep 19, 2015 01:07 AM
jcvgn
Sep 13, 2015 11:42 AM
