someone explain offset to me?
Old Feb 15, 2007 | 12:25 PM
miksen's Avatar
FU, FU, FU, You're Cool..
just lowered the max.
I need new rubber and was plannign on gettign a package deal with wheels.
I know I need some type of offset t omake the wheels flush with the body.
I thought the larger the offset the further out the wheels would be.
The other day reading a post that some one should add spacers and the offset was like +40
I want to get azul 18x8 speed mesh, wheelfire.com has them for like $539 for a set of 4 the offset is 40.
Old Feb 15, 2007 | 12:55 PM
ewuzh's Avatar
The lower the offset, the farther out the wheel is. (ie. +30 comes out more than a +40)
18x8 +40 will fit perfectly fine, though it is a conservative fitment. Personally I'd go with a more aggressive offset like +30 in front, and +20 in rear, but you might need to roll your fenders for that.
Old Feb 15, 2007 | 01:27 PM
coolmax05's Avatar
Like he said, the less positive the offset the more flush with the wheel wells.
Check out this link http://www.1010tires.com/WheelOffsetCalculator.asp
Old Feb 15, 2007 | 01:29 PM
miksen's Avatar
cool..thanks for taking the time to educate me.
Old Feb 15, 2007 | 01:31 PM
miksen's Avatar
anyone know the stock offset?
Old Feb 15, 2007 | 01:44 PM
coolmax05's Avatar
Don't be afraid to use your search functions. These questions have been answered numerous times.
For your particular year +45mm.
For 6th Gen +42mm.
If i were you I'd go with something under +35mm.
Remember, 2.54 cm = Inch So lets say you go from 40mm to 30mm
thats a 10 mm difference wich equals 1 cm
1/2.54 = about .4 inches. This means 10mm less positive equals about .4 inches sticking out more making it more flush with the wheel wheels.
RinconI30
Jun 11, 2016 08:25 PM
mpbclutch33
Sep 21, 2015 01:54 PM
steveyphat
Sep 15, 2015 03:43 PM
jfl330
Sep 4, 2015 01:44 PM
