Rubbing issues
Old Mar 17, 2007 | 07:00 AM
Killercam2's Avatar
Rubbing issues
Ok, here is my dilemma, I have a 2000 Max with stock nissan 350z rims. In the front I have 225/45/18 and 245/45/18 in the rear. I was psyched when I finally put these rims on but only flaw is that I had rubbing issues in the rear everytime I hit a bump. With the stock suspension I was rubbing and now I have k-sports coilovers and I continue to rub everytime I hit a bump. Hence, I had was to set the damper to hard to prevent the car from bouncing. So you could imagine what my ride is everytime I hit a bump.
Anyways, I am not sure what the rim size is (probably 18 x 8, not sure) but would it be possible to fit a 235/40/18 tire in the rear?
Old Mar 18, 2007 | 12:45 AM
ewuzh's Avatar
Yes and that would be the correct tire size you should be running.
Old Mar 18, 2007 | 04:19 AM
Killercam2's Avatar
Thanks ewuzh
Mar 12, 2020 12:06 AM
Serotta33
Sep 17, 2015 12:14 PM
BrandonCause
Sep 14, 2015 10:41 PM
Mikes14Max
Advance Paint and Body Work
Sep 14, 2015 05:28 PM
thenewguyy
Sep 12, 2015 11:12 AM
