Leaking/seeping issue with toyo proxes4's on 5zigens fno1r-c
Old Apr 3, 2007 | 09:38 PM
supazn
Hey guys, I don't know what is wrong but hopefully someone can point me in the right direction. These rims and tires are only a week old. The tires and rims are brand new and nothing is wring with them. It is a 235/40/18 tire on 18x7.5 rims. Air seems to be seeping out where the rim and tire meet. Definitely not the valve stem. why? how? Are toyo proxes known for this issue?
The fronts leak and level out around 25psi and the rears stay at a constant 35 psi. The max psi that the tires can handle is 50... Anyone with some advice would be helpful.
Is 25psi safe to drive on?
Old Apr 4, 2007 | 09:15 AM
ewuzh's Avatar
If they're new, then there is a warranty. Take it back to the shop and tell them about it. The tire could have been installed improperly or there could be a razor-thin slit somewhere.
Old Apr 4, 2007 | 01:18 PM
supazn
are my tires too wide?
Old Apr 4, 2007 | 04:45 PM
ewuzh's Avatar
I've run 235's on a 7" before, so they should be fine on a 7.5" Check the tire manufacturer to see the recommended range of wheel widths for that particular tire size.
Old Apr 23, 2007 | 06:47 AM
soundmike's Avatar
Very sound, Mike
Your tires may be too wide. Toyo recommends 225/45/18's on a 7.5" wide rim. I believe the only other size available for that width is the 245/45/18" Proxes 4.
Mar 12, 2020 12:06 AM
conansriver
Nov 18, 2015 02:46 PM
wingnut2006
Sep 19, 2015 06:13 AM
BrandonCause
Sep 14, 2015 10:41 PM
Mikes14Max
Advance Paint and Body Work
Sep 14, 2015 05:28 PM
