255/35/18 step in..
Old May 23, 2007 | 01:54 PM
1FSTMAX's Avatar
255/35/18 step in..
Any body have this particular tire size on their maxima? I'm thinking of picking up a set of tires with this size. I would like to know if there would be any rubbing with a 42mm offset wheel?
Old May 23, 2007 | 05:05 PM
showoff's Avatar
c'mon FSTMAX you should know better than to leave a half assed post like this...
whats the rim width??
Old May 24, 2007 | 08:25 AM
Chunger's Avatar
My other car is a Hybrid
Rim width won't matter much because the centerline of the tire will be the same... so it won't affect rubbing much unless he is gonna run something like an 11 inch width.
Al, you definitely will rub on a full turn against the frame... i do slightly with my 35ET and 245s but just slightly.
gigabyte
Jan 6, 2017 06:05 PM
JoshG
51
Sep 21, 2015 10:41 PM
Y2kMaxima
Wheels/Tires
Sep 14, 2015 10:56 PM
