Perfect offset??
Old Aug 9, 2007 | 09:01 PM
RIPTIDER's Avatar
Perfect offset??
I was looking for some rims for my 96 maxima.
These are staggered though. The specs are 16" x 8 in the front with a 38offset.
And 16"x8.5 in the back with a 32 offset.
Will this equal flush as possible with the fender or do I need to do some more research on what the heck offset it should be for a 4 gen?
Any info or constructive flamming is appreciated, as long as their is some information too.
Old Aug 10, 2007 | 12:33 AM
Fast1one's Avatar
No staggering, look for something else...
The way 4th/5th gens are, you NEED spacers in the rear to have it flush like the front, around 10-15mm depending if you roll your fender (which you need to do for clearence)...
With an 8 inch rim, your looking at around a +25 offset to have it flush in the front, 9 inch rim around +38
9 inch wheels with 35 (38 may be a little better, but I like a little rim poke ) offset are fairly flush with the front, so just use the offset calculator, plugging in different combinations of widths and offsets to get the desired size and keep it flush....thats what I do...
Old Aug 11, 2007 | 08:48 PM
z32drifter's Avatar
Looking for something like this???
17x8.5 +40 front with a 255/40 and 17x9.5 +38 rear with a 275/40
Old Aug 29, 2007 | 08:58 PM
97blackv1's Avatar
Damn that rim and tire combo looks badass!
May i ask where did you get the rims?
Old Aug 30, 2007 | 03:24 PM
z32drifter's Avatar
They are Enkei RPF1s you can get them from www.tirerack.com or www.edgeracing.com just to name a few.
side shot
Old Aug 30, 2007 | 07:42 PM
97blackv1's Avatar
Sweet!
Thanks Man,I'll check it out.
Old Sep 3, 2007 | 01:44 PM
huyqvu's Avatar
my 17x8 dont rub but for some reason my 18x8 rub in the back.
Old Sep 3, 2007 | 03:35 PM
Fast1one's Avatar
Pretty worthless, didn't give us an offset, either way just roll your rear fenders, problem solved
Old Sep 5, 2007 | 09:27 PM
NmexMAX's Avatar
dot dot dot ...
http://forums.maxima.org/showpost.ph...61&postcount=2
http://forums.maxima.org/showpost.ph...06&postcount=2
http://forums.maxima.org/showpost.ph...74&postcount=2
http://forums.maxima.org/showpost.ph...11&postcount=5
chisam14
Nov 6, 2018 08:56 PM
D Mason
Jun 21, 2016 04:43 AM
RinconI30
Jun 11, 2016 08:25 PM
mpbclutch33
Sep 21, 2015 01:54 PM
steveyphat
Sep 15, 2015 03:43 PM
