Nitrogen Air
Old Aug 15, 2007 | 09:52 AM
STILLENGLE's Avatar
Nitrogen Air
I heard if you fill your tires with this. it surposely gives you better gas milege.
Old Aug 15, 2007 | 10:49 AM
Black92GXE's Avatar
Boomer Sooner
I've never heard that , just that the nitrogen doesn't excape or something like that ... which I guess if you get your tires at the correct pressure and it stays there, it will help with mileage??
Old Aug 15, 2007 | 11:42 AM
STILLENGLE's Avatar
i know ive heard of it somewhere.
Old Aug 15, 2007 | 01:30 PM
BLACKonBLACK98's Avatar
Former Vendor
there was a thread on here all about it but it disappeared. the benefits are no moisture, less likely or slower to leak, and doesn't expand/contract as much w/ temp. change. only benefit as far as gas milage would be maintaining correct psi.
Old Aug 15, 2007 | 01:36 PM
AlpineGt66's Avatar
how much does this cost? sure "sounds" cool, but not sure if there is a real advantage other than having a lighter wallet
Old Aug 15, 2007 | 01:59 PM
NmexMAX's Avatar
dot dot dot ...
Fill 'em with Methane.
Old Aug 15, 2007 | 07:29 PM
irish44j's Avatar
retired moderator
^^he is correct.
btw, when "the shop" puts nitrogen in your tires it's usually not "pure" but about 90% Nitrogen and 10% oxygen.
but unknown to many, regular "air" already is about 75% nitrogen, naturally.
so basically, you're paying extra for a whole lot of nothing. Some racers use pure nitrogen only because it doesn't expand as much when it gets hot, so tire pressure stays more constant.
Old Aug 16, 2007 | 06:37 AM
STILLENGLE's Avatar
so theres really no benefit to it at all and no MPG change.
Old Aug 17, 2007 | 07:15 AM
burnurass's Avatar
if you put the responses together, you'd come to the conclusion that THERE IS A BENEFIT..but not MUCH since it's not PURE nitrogen at most place. YOU get BETTER MPG because of Correct Tire pressure.
tarun900
19
Dec 20, 2021 06:57 PM
aw11power
Oct 10, 2021 04:57 AM
Miket2006
Mar 1, 2021 03:55 AM
Justin Kroll
Oct 1, 2015 07:03 PM
MichMaxFan
Sep 30, 2015 09:18 AM
