OZ Racing F1 Wheels 17x9, 5x114.5
Aug 27, 2007 | 02:50 PM
Would 17x9's fit on the front of our Maxima's? I know it'll fit in the rear.
These came off of a 300ZXTT.
Aug 27, 2007 | 02:55 PM
might make it if the offset is just right. otherwise i think it would poke or rub on the inside at full turn.
Aug 27, 2007 | 02:58 PM
Tried to google for the offset but can't seem to find it.
Aug 27, 2007 | 05:41 PM
Depends if you mind if they stick out.... the offset should be marked inside the wheel. A 17x9 +35 will fit, but sticks out about 5mm depending on how much tire you put on it.
17x9 +34 with 255/40
Aug 27, 2007 | 08:39 PM
Z32D, few mm is still flush in my book Always loved your wheel setup...
Ok, as far as the offset goes, all you need is a ruler and the wheel
https://www.rsracing.com/tech-wheel.html
Edit: This graphic is particularly helpful
Aug 28, 2007 | 08:31 AM
Here's a dumb question for you guys: Would my current tires 235/45-17 fit the 17x9?
Aug 28, 2007 | 08:50 AM
Yes but it would be stretch out... absolutely not room for curb rubbing. It should look nice though...
BTW the offset should be listed on the backside of the rims... either with a sticker or engraved/cast on the metal itself.
Aug 28, 2007 | 08:56 AM
Here's another pic. You can see the lower left rim got curbed bad.
Aug 28, 2007 | 09:01 AM
If you don't mind the style, check out the 17X8" ET40 Ultraleggeras at TireRack for $209 each.... very light (17 lbs) compared to these... I think those used ones are about 23+lbs each...
Aug 28, 2007 | 09:19 AM
Quote: Here's a dumb question for you guys: Would my current tires 235/45-17 fit the 17x9?
If you know how to drive...aka don't hit the curb, theres a reason I wont let my mom drive my car once my wheels are mounted, curb rash FTL
Aug 28, 2007 | 10:19 PM
17x9 (with proper offset, +35 or so) is the only way to go. 235/45s will be stretched if you put em on, but it won't be too bad.
Not sure how big a fan I am of the looks though.
Aug 28, 2007 | 10:41 PM
Quote: 17x9 (with proper offset, +35 or so) is the only way to go. 235/45s will be stretched if you put em on, but it won't be too bad.
You got the right idea
Yeah, in reality, anything in the 30s should be great, but yeah +35-38 is the sweet spot for that width...
