Plastic hub rings vs metal hub rings?
Old Sep 6, 2007 | 03:56 PM
n3985's Avatar
大陆弟弟
When mounting after market wheels, I know hub rings are a must. But is there a big dif between the plastic and metal ones? The cheapest I found online for plastic was $39.99, anyone know a place for cheaper?
Old Sep 6, 2007 | 05:28 PM
z32drifter's Avatar
Try www.discounttiredirect.com I picked up set of metal ones from them, on one of their ebay auctions for like $15. I have both plastic and metal ones, the metal ones hold up much better, plastic ones get hard and crack over time.
Old Sep 6, 2007 | 06:26 PM
BEJAY1's Avatar
Conecarver
$39.99 is a ripoff. Hit up Discount Tires or Tirerack. They're like $10 or less. Metal are nice but I find em harder to get off after they heat up nice. Oh, and the plastic ones can be filed down easier to fit Enkei that doesn't like the full thickness.
Old Sep 6, 2007 | 06:28 PM
n3985's Avatar
大陆弟弟
eBay has polycarbonate ones, which they say is better than metal since it does not corrode?
Old Sep 7, 2007 | 02:57 PM
ThurzNite's Avatar
What size do you need? I have 3 sets of plastics sitting around. 1 set is brand new.
Jae
Old Sep 7, 2007 | 03:00 PM
n3985's Avatar
大陆弟弟
Have no idea, planning on getting wheels soon so getting the stuff I need first. I thought all wheel manufacturers make their bore big enough to fit most hubs, so any hub rings made for a Maxima should work with any aftermarket wheels right.
Old Sep 7, 2007 | 10:46 PM
ThurzNite's Avatar
http://www.1010tires.com/hubrings.asp
Tomorrow I'll use my caliper to measure the ones I have.
Jae
Old Sep 13, 2007 | 06:30 PM
Ammi's Avatar
350 Detroit Muscle
I got metal ones for about $10 from discount tire. Only bad thing about metal rings are that they rust over time and you might have to chisel them off.
Old Sep 14, 2007 | 10:57 AM
phenryiv1's Avatar
Mod her. Ate her.
If you have a local "Trick Trucks" they sell them. I got mine for $7-8 for a set of 4.
doctorpullit
Mar 29, 2016 11:08 AM
sliptap
Sep 30, 2015 05:57 AM
Andy29
Sep 29, 2015 05:32 AM
Pied
Sep 26, 2015 03:29 PM
