Tire Size for 5.5 Gen (2003 I35)
Old Nov 13, 2007 | 03:56 AM
JMWarren's Avatar
Hi Guys,
I've got stock tires and rims @ 215-55R17
Is it safe or advisable to run 235-50R17?
I know they'd be wider but should still fit the rim, would this soften up the ride a little?
Thanks!
Old Nov 13, 2007 | 05:15 AM
soundmike's Avatar
Very sound, Mike
From the various set-ups i've had, a taller, narrower tire have always felt softer and comfier than a shorter tire, wider tire.
Old Nov 13, 2007 | 09:04 AM
AnDyMaN's Avatar
235 isn't supposed to be on a 7" wide rim. i think if yo usearch the informatino would be easily found.
225 is the "widest" on a 7" rim. i have put a 235 tire on the 225 rim without problems, as have money others.
btw, the 215/55 has a very miniscule amount of more sidewall. so the 215 would probably provide a intsy tinsy bitsy more cushion.
Finkle
Sep 27, 2015 09:53 PM
tcb_02_max
Sep 11, 2015 12:23 PM
MikesChevelle
Aug 19, 2015 07:19 AM
MaxStock
Aug 14, 2015 10:03 PM
MaxStock
Aug 12, 2015 08:33 AM
