What size spacers would you recommend?
Old Jan 11, 2008 | 11:28 AM
  #41
!PrjctMax!'s Avatar
Originally Posted by redmaxpa007
so, the 5mm is good for the fronts..
but 15mm is making you looks silly on the rear....
? that is what you are saying?
pretty much ya...but would actually putting the car on the ground have that much of an effect on it that it would look much "better" w/o rubbing?
did you try 5 mm on the rears?
drrrrrrrrrrrr after I took the washers off and put both wheels back on I thought of that... I'll try it either later on tonight or tomorrow.
I also have to get some tuner lug-nuts because I'm starting to knick these wheels up!
Old Jan 11, 2008 | 11:31 AM
  #42
redmaxpa007's Avatar
i SeE what you did therE
hello????????? where did you go?
Old Jan 11, 2008 | 11:33 AM
  #43
how much are you willing to spend?
my personal choice is Mcgard Spline luts with or wthout locks
one key for the regular lugs, another key for the locks...
Old Jan 11, 2008 | 11:50 AM
  #44
!PrjctMax!'s Avatar
......"hello where did you go?" I was ordering the lug-nuts...lol $40.90 shipped for these... http://store.summitracing.com/partde...5&autoview=sku
EDIT-wow...I just ebayed yours and that's a little out of my price range for "lug-nuts" lol
Old Jan 11, 2008 | 11:52 AM
  #45
ok.... those are fine....
  #46
!PrjctMax!'s Avatar
BACK ON TOPIC...
Old Jan 11, 2008 | 01:44 PM
  #47
Fast1one's Avatar
You probably have loads of positive offset man, you should just measure when its on the ground and use your imagination, its not rocket science, you are making it harder than it needs to be...
You already measured the rear to be ~5mm more sunk then the front, so if you really like how the front looks, just add 5mm to the rear spacer...
So 5 front, 10 rear, DONE
Edit: On further inspection it looks like the front needs around 5mm and the rear 15mm, if your pictures are accurate...it will compress a good deal once its on the ground and move inward...
Edit edit: BTW, you can prop your car on jack stands (if you haven't already) and use the jack to CAREFULLY jack the suspension up until it is at stock level, just watch the jack stand because you don't want your car to fall off it obviously...
Old Jan 11, 2008 | 07:54 PM
  #48
!PrjctMax!'s Avatar
I know it's not rocket science...that's why I'm frustrated because such a "simple" thing is being so "difficult!" lol
The front washers that I had totaled out to be around 6mm, so 5mm spacers should be good.
Even if the rears sink in once on the ground, they still look "too wide" for my tastes.
Either way, I am going to try 5/10/15 set-ups tomorrow and use your method ftw.
thanks
dan
Old Jan 12, 2008 | 01:23 AM
  #49
Fast1one's Avatar
thanks
dan
Just use 10 in the rear, should be fine
Old Jan 17, 2008 | 06:23 PM
  #50
MyownNismo's Avatar
Future Camaro SS owner
If you bought the 15mm H&R's and don't like them and are selling I would be interested.
Old Feb 4, 2008 | 09:35 AM
  #51
Rekinyze's Avatar
5mm in the front (you're almost flush already)....and 15mm in the back.
Miket2006
Mar 1, 2021 03:55 AM
knight_yyz
Nov 1, 2015 01:34 PM
MaxLvr21
Oct 17, 2015 12:11 PM
coolsun
Wheels/Tires
Oct 15, 2015 10:52 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
