Tire Size Question
Old Feb 27, 2008 | 04:08 PM
jattdemax's Avatar
Tire Size Question
Okay, so I have a set of 18" wheels with the tires sizes 245/45/18 front, and 225/45/18 rear. Will I have any rubbing issues at all on my 95 SE? Thanks guys.
Old Feb 27, 2008 | 04:22 PM
NmexMAX's Avatar
dot dot dot ...
The 245-45's will probably rub. Why not get 245-40's all around?
Old Feb 27, 2008 | 05:11 PM
jattdemax's Avatar
I would, but the thing is the tires are on the wheels already. They came off a G35 coupe. Hope they fit.
Old Feb 27, 2008 | 06:20 PM
Fr33way™'s Avatar
Wild for Width
The 245/45s need to go in the BACK.
Old Feb 27, 2008 | 06:38 PM
jattdemax's Avatar
will the 225/45/18 fit in the front?
Old Feb 27, 2008 | 10:26 PM
Fast1one's Avatar
There is more room in the back then the front...
To give you a more accurate answer, we would need to know what kind of rims, or atleast the width and offset...Since they came off a G35 coupe, I am assuming they are the forum boner 7 spokes judging by the tire sizes...
STICKY, right up there ^^^ in the Wheels and Tires section
Old Feb 27, 2008 | 10:27 PM
SEmy2K2go's Avatar
Go BUCKS!!!
Get 235/40/18 all around and you'll be set.
Old Mar 2, 2008 | 08:56 AM
bryguy1822's Avatar
I have an 08 maxima sl. I'll be purchasing some 19's real soon. What do i need to avoid the TPMS light coming on?
Old Mar 4, 2008 | 02:44 PM
xorox's Avatar
it seems that 17x7 is the size for my 98 maxima gle, im considering black rims with a red lip? my maxima is black with the silver outline for the windows and door handles-98 gle maxima. any suggestions on a really light rim but sexy ? dont want to spend too much either, thanks.
Old May 19, 2008 | 05:58 PM
nowicki13's Avatar
Just an FYI - Factory Tires on my 00 are 225/50/17" which are 225mm wide by @660mm in diameter. Your 225/45/18's are also 225mm wide by 660mm in diameter. I don't know what OEM size was for the 95 -but I'm guessing those will fit fine -and yes, the wider ones should go on the rear. Like the other poster says, it is rim size that is probably more critical. I think those rims are 8" wide, which may cause problems.
I just had 18x7.5 akita AK2's delivered and am waiting on 225/45/18 General Exclaim UHP's to arrive. I did the math for my 2000 SE and the difference should be only .45" wider than the 7" factory rims and exactly the same diameter. I have a spreadsheet that I'll share with anyone who wants. It has a bunch of the lower cost tire sizes and brands in 17, 18, and 19" sizes. It won't display here correctly.
Last edited by nowicki13; May 27, 2008 at 11:42 AM. Reason: Excel spreadsheet didn't display correctly.
Old May 19, 2008 | 06:44 PM
z32drifter's Avatar
^^^ Just a FYI fix what ever the F is going on under your post.
Old May 20, 2008 | 05:33 AM
LeX's Avatar
LeX
Nissan by Nature
those will rub.. i bought the same wheels... 245 45 18 rub BAD on the back of a 5.5gen you have to roll your fender lips but i replaced the tires.... not the best size
Old May 20, 2008 | 08:49 AM
WhiteA32's Avatar
I have the same tires on my 4th gen. I have 350z wheels. I rub in front a few times, but never in the rear....
Old Mar 19, 2012 | 02:59 PM
aniserrano's Avatar
I have a 6th generation Nissan Maxima, I went in for new tires. They recommended 245/18/45 and they rub. What can i do?
Old Mar 27, 2012 | 07:50 PM
asand1's Avatar
Take them back. They f'ed up, and need to set you up with tires that fit. Also, bumping a 4 year old thread for an unrelated question will get you flamed.
Welcome to the forums.
Old Mar 28, 2012 | 11:43 AM
NmexMAX's Avatar
dot dot dot ...
^^^ what he said.
Check the sidewall and ensure that they are indeed the size they said they were.
I'm assuming you have OEM wheels and that you are not lowered?
The Frye
Sep 2, 2021 11:03 AM
Johnny9595
Sep 3, 2015 05:18 AM
sdotcarter
Sep 2, 2015 09:53 PM
maximaham
Aug 20, 2015 10:23 AM
