Will I rub with these wheels and tires? 5th gen
Old Apr 2, 2008 | 05:26 PM
n3985's Avatar
大陆弟弟
Looking to buy a set of 19s and I have the following options:
19x8.5 +38
Or
19x8.5 +32 F 19x9.5 +35 R
All with 245/35/19 on my 5th gen I35 dropped on Eibachs. Thanks!
Old Apr 2, 2008 | 05:39 PM
NmexMAX's Avatar
dot dot dot ...
The 9.5"s might rub, but all the others are fine, IMO.
Old Apr 2, 2008 | 05:53 PM
n3985's Avatar
大陆弟弟
So better off running 8.5 +38 all around and 5mm spacer front, and 15 back?
OR do 8.5 all around but 32mm for all 4?
Old Apr 2, 2008 | 05:54 PM
NmexMAX's Avatar
dot dot dot ...
You will rub with the spacer and that offset in the rear.
Old Apr 2, 2008 | 06:14 PM
n3985's Avatar
大陆弟弟
Which one? the 38 or 32? Thought you were 18x8.5 +33 with 15mm in the back? 245 tires too right?
Old Apr 2, 2008 | 06:17 PM
NmexMAX's Avatar
dot dot dot ...
Ya, and I rub on 1 side. 9.5" + 35mm + 15mm spacer, IMO, would/will rub.
Old Apr 2, 2008 | 06:48 PM
n3985's Avatar
大陆弟弟
You know if 8.5 +32 can be run on the front? Or too low offset? Thanks for the help!
Old Apr 2, 2008 | 06:50 PM
Fast1one's Avatar
9.5 +35 with no spacer and rolled fenders should not rub...
8.5 +32 should be fine up front...
Old Apr 2, 2008 | 08:44 PM
MrDicks95SE's Avatar
Offset Is Everything.
8.5 +32 will be fine. no problem. in the rears with a 15mm spacer you WILL rub. roll your fenders and see where you're at.
Old Apr 3, 2008 | 04:07 AM
n3985's Avatar
大陆弟弟
I know that 5th gens need a low 20 offset with 8 or 8.5 wide wheel to be flush. So now that +32 is known to clear the front, I'll prob only do a 10mm spacer in the rear.
Old Apr 3, 2008 | 05:32 AM
LeX's Avatar
LeX
Nissan by Nature
yeah just roll the rear fenders... but it all depends on the drop... I had 265 35 18 and 18x9.5 38 offset and only rubbed over big dips... now i have some higher pro tires on there as i swapped rims and 18x8 245 45 18 rubs so im getting some 225 45 18s to match the front tires
Old Mar 10, 2010 | 12:22 PM
*2003MaxipadSE*'s Avatar
I know this is an old thread BUT...i need some help. looking to get 18x9.5 in the rear with 275/35/18 tires. Offset 25mm. Will this rub at all? I have a 03 max SE
Old Mar 10, 2010 | 06:12 PM
Fast1one's Avatar
How much you will rub depends on how low you are. But you WILL rub in the rear with 275s, even with rolled fenders. Offset is too low for the size tire you want to run.
Run 255s and roll your fenders and you'll probably be fine with just a 1.5 inch drop.
Old Mar 11, 2010 | 06:47 AM
The deal i found comes with brand new tires in that size...so im trying to decide if its worth trying..right now im still running stock suspension so I was hoping all would work. Its a really good deal Heres the link to what im looking at.
http://cgi.ebay.com/ebaymotors/18-AD...Q5fAccessories
Old Mar 16, 2010 | 07:50 PM
95maxrider's Avatar
Lightly modded
So I stumbled upon these wheels/tires FS earlier.....
Fronts are 17x8+35 225/45/17
Rears are 17x9+45 255/40/17
I already have my rear fenders rolled, so is there any chance I can run that offset in the rear? I know I should know this, but I don't....I'm assuming no....
Old Mar 17, 2010 | 01:56 AM
IHAVEA2KMAXIMA's Avatar
I'm pretty sure they will fit without any sort of problems
Finkle
Sep 27, 2015 09:53 PM
cheftoo
Aug 24, 2015 09:20 AM
twotonezed
Aug 16, 2015 11:41 AM
RealityCheck
Aug 5, 2015 06:18 AM
