g35 coupe 19s rub in front :(
I got new rims for my g, so I put the 19s from my g on my new 97 max.
Tire size is 235/35/19
And after i first put them on i noticed the offset is ay to agressive and they stick out far past the fender... Didnt like this, then after taking a drive i noticed the tire rubs the back part of the wheel well( part above the spash gaurd.
Im on eibach springs to, im kinda sad about this .
the rims so look good on it, just needs to b lowed more. Ill tak some pics tomoro but the rims are prolly coming off...
This stick out? Thats kinda doubt full unless I am missing something. G Sedans don't have very aggressive offsets or widths...usually 8 inches wide with a +35 offset IIRC...
As far as the rear, thats easy to fix. Just roll your fender, its very easy to do...the fronts can just be cambered in as they stick out an extra 15mm than the rear unless its staggered...
I had them on my G sedan . But when they were on the G everything was perfectly flush.
On the max the rear was perfectly flush, but the fronts stick out almost an inch past the fender !!!
looked terrible and rubbed so the rims are offand im back to stock 16"s
That can't be right, theres something really wrong if you are rubbing in the front...Im running 9.5s up front with 245s and a 1.5 inch drop with no rubbing...
i have 18" rays touring off the 350z with +33 offset and i think it sticks out a little too. unless the installer got the rims mixed up with the front and rear (put the higher offset in the rear)
Hdnseek
09-09-2015 05:55 AM
