Kosei K1-TS 17x9: Will I rub? What offset?
Old May 9, 2008 | 05:22 PM
MOHFpro90's Avatar
I contacted Tirerack via email, and their Kosei K1-TS are on closeout, the 17x9s are at a steal price right now. The wheels are amazing, light and look dang good. I have a few questions though. I plan on running either 255 Nexens, Kumhos or (maybe) Yoko S.Drives. I want to make sure I wont rub, will I? Also, the guy at Tirerack only mentioned 35 offset. I'm not sure what stock offset is, should I have to go higher than 35mm with the 9in rims? I want them to sit flush(who doesnt?). Thanks in advance.
Old May 9, 2008 | 05:56 PM
MorpheusZero's Avatar
They have less than 2 17x9s left at that ridiculous price. I saw that awhile ago.
Old May 9, 2008 | 05:57 PM
BLACKonBLACK98's Avatar
Former Vendor
flush in the rear for a 9 would be around 30mm but 35mm is close enough. the front should be good, maybe a slight poke depending on how you measue such things. i would think you would be fine with a 255, but depending on your drop maybe roll your fenders. i wouldnt worry about it too much. all in all sounds like a go.
Old May 9, 2008 | 10:37 PM
MOHFpro90's Avatar
Morpheus, I contacted the guy and he said they had a set. I emailed him back and asked to make sure there were 4 left, no response yet.
Thanks for the help BoB (hahaha, abbr.)
Incase they dont have 4 17x9s, I will do 2 17x9s and 2 17x8s.
Old May 10, 2008 | 11:35 AM
MrDicks95SE's Avatar
Offset Is Everything.
i'd go +25's in the rear for really nice flush but a roll and slight pull if you're running those size tires. go +30 if youre worried about rubbing with 255s.
high 20's to low 30s for the front with 235's should be no problem if you go with 8" wide.
Old May 11, 2008 | 01:15 AM
DrunkieTheBear's Avatar
Turbo'd Saab
kyle you can't always be like me, even though most of old parts are on your car. LOL
you need a 35mm offset.
Old May 11, 2008 | 01:21 AM
Yeah, forgot to add--35mm all around should be good, maybe try +30 or +25 or so for the rear if you're into that kind of stuff
Old May 11, 2008 | 09:26 AM
MOHFpro90's Avatar
So Mr****s95, you dont think I can run 9" wide in the front?
I guess if we wanted to, Dave, we could just test fit your FN01RCs with 255s first...
Old May 11, 2008 | 01:09 PM
Fast1one's Avatar
9 in the front is cake walk...35-40mm offset with small spacer in the rear, or 25-30mm offset with the fronts cambered in
Old May 11, 2008 | 01:50 PM
9 in the front is fine, he was merely stating that if you had to get 8s then 8 +30 would work well in the front.
Old May 11, 2008 | 07:44 PM
MOHFpro90's Avatar
Ok, I see. I should get a response from the sales rep tomorrow on how many they have left.
Old May 11, 2008 | 10:20 PM
i never said that. you can run 9.5" with the right offset if you wanted to. just stretch the tire a little to prevent rubbing.
RinconI30
Jun 11, 2016 08:25 PM
mpbclutch33
Sep 21, 2015 01:54 PM
Serotta33
Sep 17, 2015 12:14 PM
steveyphat
Sep 15, 2015 03:43 PM
thenewguyy
Sep 12, 2015 11:12 AM
