would staggered wheel fit 02-03 maxima
Personally I'm not sure if I would EVER stagger with a maxima, but if you really want to, +35mm offset all around with those widths will work perfectly. You will have to roll your rear fender for clearence under compression...
Yes you can put stag fit rims. I did a few before axis sell a nice set up but i only did 20s. they were 20.8 frt and 20.9 ashanti wheel they look nice but you have the rotation issue and tires arent that cheap 225 30 in the front and 265 or 275 30 20 in the front lowered and roled fenders my wife had that one but it was stolen in fl
In order for me to validate this comment, I need a little more information from you.
1.) What size tires are your G wheels wrapped in?
2.) We all know, or should know, the reason for only rubbing on 1 side, mine too rubs only on the passenger side w/ 8.5" wide / +18mm.
alright 8.5 +30-ish for the sake of meaty tires. 245 fronts. rears need to be low offset tho
trasmadean
02-01-2017 08:20 PM
BassAddictJ
08-04-2015 11:38 AM
