Will i have rubbing issues
Old Jul 1, 2008 | 04:11 PM
Crusher103's Avatar
i was just shopping around the local tire dealers today and quite a few of them said that i will have rubbing issues with the size of tires that i want so i just want to clear this up:
My wheels are 17x8 with a 38mm offset, i want to put 245/45 on them, my rear tires are already 245. According to the computers at these shops the biggest i should go is 235 which is what i am currently on.
Im just trying to get some clarification on if i can go with 245s i dont think anything bigger than this will fit on my current wheels, this is a 4th gen I30 btw
thanks
Old Jul 1, 2008 | 08:13 PM
BLACKonBLACK98's Avatar
Former Vendor
i really really doubt it, but if all else fails roll the fenders.
Old Jul 1, 2008 | 10:19 PM
MrDicks95SE's Avatar
Offset Is Everything.
You can fit 245s on an 8. Different manufacturers may be wider than others but overall fit will be fine. That would be THE widest on an 8. 235 is the recommended size though.
As far as rubbing with 245s, i doubt it.
Old Jul 1, 2008 | 10:27 PM
Crusher103's Avatar
k thanks
Mar 12, 2020 12:06 AM
Serotta33
Sep 17, 2015 12:14 PM
BrandonCause
Sep 14, 2015 10:41 PM
Mikes14Max
Advance Paint and Body Work
Sep 14, 2015 05:28 PM
thenewguyy
Sep 12, 2015 11:12 AM
