350Z wheels on Max 2k??
Old Aug 15, 2008 | 11:10 AM
Parthur's Avatar
I am getting a set of 4 winter tires and steelies. they are size Artic Claw 225/55/17, that came from a 350Z.
Now my question is will they fit my maxima 2000, the OEM tires are 225/50/17 I know the measurements should be ok, but the bolt pattern is my concern?
I really do not know much about wheels/tires, so I really need info.
Old Aug 15, 2008 | 11:13 AM
Should be fine.
Old Aug 15, 2008 | 01:01 PM
NmexMAX's Avatar
dot dot dot ...
How is your suspension set-up? I'm guessing not so low if you do a lot of winter driving. That size is a bit taller than stock, and might rub on certain instances. What size are the actual wheels? Are the staggered?
Use the tire calculator located in the sticky on the top of this sub forum for information regarding your speedometer.
Old Aug 15, 2008 | 01:04 PM
BLACKonBLACK98's Avatar
Former Vendor
lol @bolt pattern concerns from a 350 to a max. somebody hasn't been paying any attention at all.
Old Aug 15, 2008 | 04:02 PM
Parthur's Avatar
The suspension is stock, I am driving with goodyear 225/50/17 (stock) with stock rims 17 for SE.
As I say I don't know much about wheels and tires so I want to make sure those winter tires won't become a problem later on. Yes I do lots of snow driving ( Canada ).
Also I am not sure about the tires themselves, are arctic claw good ones?
Thanks again!!!
Old Aug 21, 2008 | 10:30 AM
NmexMAX's Avatar
dot dot dot ...
Ok, so, still no further info on actual wheel tire specs.
matts95max
Apr 23, 2025 10:44 AM
MaxLife17
Jun 27, 2019 01:37 PM
BkGreen97
Apr 2, 2016 05:47 AM
MaxLife17
Sep 8, 2015 02:36 PM
coasterswim
Sep 2, 2015 07:43 AM
