Will these fit?
Old Sep 8, 2008 | 06:51 PM
houseofgrafx's Avatar
Will these fit?
Will wheels that fit a 1999 BWM 540i sports package fit a 98 Maxima? I don't know much about offset & backspacing so any help is greatly appreciated.
The reason I'm asking is there is a set I'm looking at on ebay (millie miglia's) so if they would fit I'd pick em up.
Thanks!!
Old Sep 8, 2008 | 07:52 PM
IHAVEA2KMAXIMA's Avatar
I think they have different lug pattern, so you will probably need a 15-20mm spacer to convert to euro specs. I'm not sure what their offsets are but I would guess they wont really fit after having that huge spacers in between. Sorry that I'm not really helpful lol.
Old Sep 8, 2008 | 08:18 PM
I appreciate you taking the time to try to help lol. I wish they would fit but you're right. I don't think they will.
Old Sep 9, 2008 | 12:40 PM
ROCKART's Avatar
wants an I35
i think most BMW wheels have extremely low offsets as well, sometimes even negative offsets.
Old Sep 9, 2008 | 09:01 PM
Fast1one's Avatar
Never really seen many with negative offsets, if at all. But yes generally BMWs have lower offsets than ours since they are RWD...
Old Sep 9, 2008 | 09:21 PM
MorpheusZero's Avatar
IIRC all modern bimmers are 5x120mm lug pattern, so you will need a converter.
As for offsets, yes they will be less but certainly not a negative offset. That is just a bad idea from an engineering standpoint, you want the centerline of the wheel to be close to the wheel bearing to prevent excessive runout-type stress and wear.
Old Sep 10, 2008 | 04:18 AM
Thanks guys. I went another route. I picked up a set of 350z 35th anniversary wheels. Now I need to figure out if they need spacers or not lol.
Sorry for the questions guys but being a female & trying to mod a car sometimes don't mix..
Old Sep 10, 2008 | 08:34 AM
Fast1one's Avatar
You'll be fine with those wheels...no spacers needed...
Old Sep 10, 2008 | 09:49 AM
Awesome. Thank you!!
Old Sep 10, 2008 | 10:27 AM
MrDicks95SE's Avatar
Offset Is Everything.
a lot of guys are running 350z wheels here with no problems.
Old Sep 10, 2008 | 03:59 PM
What size tires for the 350z wheels?
Old Sep 10, 2008 | 07:51 PM
are they 17s or 18s? i forget. either way these sizes would be preferable for 4th gens on 8" wide wheels:
235/40-18
or
235/45-17
if you want a tad more rubber go with 245s.
Old Sep 11, 2008 | 06:24 AM
The wheels are 18x8 in the front & 18x8.5 in the rear.
Old Sep 11, 2008 | 10:59 AM
235/40 front and 245/40 rear if you dont mind the staggered feel. also will induce a little understeer. if not, 235/40's all around would be sufficient.
Old Sep 11, 2008 | 01:09 PM
I was hoping to do the same all around so if the 235/40's will work on both widths I'm going that route. Thanks for all the help guys
I did send a PM full of questions to a member who has the same wheels on his car I just never heard back yet from him so I thank you guys for helping!!
Old Sep 11, 2008 | 02:02 PM
you should be good! your welcome.
Old Sep 11, 2008 | 09:14 PM
I think you would need to roll the back fenders if you're lowered or planning to lower.
But you'll look like you're riding 4x4 if you dont lower it with the low profiles. lol
Old Sep 12, 2008 | 04:44 AM
Guess I'll be riding that 4x4 because I know nothing about rolling fenders
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
Pied
Sep 26, 2015 03:29 PM
