235in front 225 in back, problem?
Old Dec 20, 2008 | 07:31 AM
Scott LaRock's Avatar
im in a tight fix budget wise right now, if i have different size tires on the car for a couple months, whats the worse that can happen
Old Dec 20, 2008 | 08:08 AM
Maximillionaire's Avatar
I'm inclined to put the larger tires in the back but this is coming from a former RWD owner. I'm not sure about FWD cars. As an exampe the Lexus IS-F has P225/40R19 in the front and P255/35R19 in the back, but that's a high performance sports car. But if I remember correctly staggered setups, rear or front, are not a problem. I think if you want more of a touring feel you'll put the larger tire in the back and if you want better traction, the larger one in the front.
Old Dec 20, 2008 | 09:24 AM
I asked this question because I honestly thought this would either screw up my alignment or damage the rack and pin or any other steering part on my Max but as long as I know I can do it for a maybe a couple months until I save up for all 4 new tires, I'm cool.
Old Dec 20, 2008 | 09:25 AM
Also, does tire width mean much? On my front two tires one is 93w and the other is 97w.
Old Dec 20, 2008 | 12:44 PM
CapedCadaver's Avatar
Call me Wookiee Goldberg
well yeah you want more grip to the drive wheels, esp on a higher powered car. an IS-F needs the wider rubber in back to keep you from spinning your rear tires. a FWD car needs the help in front... because the rear wheels do very little work compared to the fronts. on FWD, the front wheels do all the turning AND all the acceleration (and most of the braking).
therefore my official vote is to put the wider tires in front.
Old Dec 20, 2008 | 02:34 PM
PulsarGTS's Avatar
You should be ok, depending on what else you have done suspension wise over steer could be an issue.
Old Dec 20, 2008 | 02:37 PM
IHAVEA2KMAXIMA's Avatar
I put 245 in the front and 225 in the back and nothing much really happened.
Old Dec 20, 2008 | 03:20 PM
PulsarGTS's Avatar
what gen and what is done to the suspension
Old Dec 20, 2008 | 03:43 PM
A33 on COs. I had 245/40/17 on 17x8 +33 and I would rub very slightly against the inner wheel well when I turn full lock. That's about it.
Old Dec 20, 2008 | 03:54 PM
MrDicks95SE's Avatar
Offset Is Everything.
you wont have any problems. as far as general drawbacks, there really is none. the widths of the tires are fairly close so steering will feel very similar. you may feel grip is slightly better since more rubber is on the drive wheels but you're not going to have any problems. with alignment issues youre not going to have any. unless you tinker with your suspension, it wont be altered. when it all comes down to it, theres absolutely nothing to worry about.
for 93W and 97W, those are speed ratings for the tires. i wouldnt worry about that either.
Old Dec 20, 2008 | 05:37 PM
W is the second to highest speed rating and it's usually used on exotics. 270 km/h max with the Ws, 300 km/h max with the Ys. So yeah, you're good.
Lakersallday24
Nov 7, 2024 07:31 PM
kingw323
20
Oct 21, 2015 08:36 AM
doctorpullit
Aug 20, 2015 05:15 PM
FanaticMadMax
Aug 10, 2015 08:55 PM
kirkhilles
Aug 8, 2015 10:53 AM
