Installed 05 SL wheels on 01 GLE - need tire suggestions
Old Apr 5, 2009 | 11:49 PM
unrealii's Avatar
Picked up some 17" 05 SL wheels (20k miles on them) since my RE960 tires were wearing out on my 16's. Figured I could kill two birds with one stone by upgrading to 17"s and putting off a tire purchase. Lots of tread left on these conti tires.
Before 215/55/16 93W:
After 225/55/17 95V:
Closeup:
...and now after seeing how big these wheels are you may ask, won't those rub?
Yes, they do. So far only on the right rear. Looks like my best option is to buy new tires for the 17's instead go back to the 16's. I have the Eibach prokit, so I am not sure if that is what is causing my rubbing issue or if the tire itself is just too big.
I'm quite happy with the performance I have had of my Potenza 960's.
Which size would be recommended?
225/45R17 91W <- Leaning towards this.
215/45R17 91W
215/50R17 95W
There's a $75 rebate going on for the RE960's. If someone knows of a cheaper tire which will perform similar or better, please let me know. Planning to go tomorrow to the tire shop and get new tires.
Old Apr 6, 2009 | 11:09 AM
unrealii's Avatar
Checked my car and this seems to be the issue mentioned here:
http://forums.maxima.org/6587173-post5.html
The rubbing comes from the mounting tab for the front of the back bumper against the edge of the fender
I do not plan to add spacers nor roll my fender.
Old Apr 6, 2009 | 08:48 PM
2slow's Avatar
Try a 225/50/17 over the 45 and 55s. It is a 5.5 stock size.
Old Apr 6, 2009 | 11:22 PM
unrealii's Avatar
Thanks for the suggestion. I wanted to stay away from that size because it was too close to the size which rubs. I went ahead and bought 225/45/17 tires today.
Old Apr 7, 2009 | 12:16 AM
a33i30's Avatar
Looking good, try Kumho spt. Btw are you lowered?
Old Apr 7, 2009 | 12:17 AM
a33i30's Avatar
^nvmmm I hadn't seen your sig
dank4us
34
Jun 10, 2024 03:45 AM
rtirbany
Sep 8, 2015 11:46 AM
homeyclaus
Sep 3, 2015 06:15 PM
twotonezed
Aug 16, 2015 11:41 AM
dutch078
Wheels/Tires
Aug 3, 2015 06:58 PM
