Lug nut options
Old Aug 11, 2010 | 12:50 PM
Kevlo911's Avatar
Kevlo for President
Lug nut options
I currently have tuner lugs on my car, but i do not like them or the tool that it uses. The stock acorn nuts do not thread on much because of the 5mm spacer I have; but the tuner lugs get like twice as many threads in.
What options do I have?
Old Aug 11, 2010 | 01:16 PM
NmexMAX's Avatar
dot dot dot ...
Did you get longer studs with those spacers? I have 5mm up front too and they actually came with longer studs .. H&R's.
And yeah, OEM acorns suck.. Some nismos?
Old Aug 11, 2010 | 01:29 PM
Kevlo911's Avatar
Kevlo for President
No. I was lookin at gorrilla lucks to match my gorilla locks but I can't find um for a good price.
Gorilla 61127/61128
I wanted to do longer studs but since the tuner lugs catch like 6-8 threads, I do not see the need.
Old Aug 11, 2010 | 04:01 PM
NmexMAX's Avatar
dot dot dot ...
Yeah, lugs are seriously, IMO, overpriced.
Old Aug 11, 2010 | 04:02 PM
MoncefA33's Avatar
Get some Project Kics
Old Aug 11, 2010 | 07:29 PM
1hawaii50's Avatar
Kics Projects!
Old Aug 11, 2010 | 07:34 PM
Kevlo911's Avatar
Kevlo for President
I'm not trying to spend over 30bucks on lugs. I'm sure they are nice and all, but I just need them to hold the wheel on lol
Old Aug 11, 2010 | 07:44 PM
1hawaii50's Avatar
I agree that you don't need to spend $150 on lugs...HOWEVER...there are certain things IMHO, that you should NEVER skimp on. Brake components and lug nuts would be on that list. There are all kinds of dirt cheap lugs you can get, but I don't know if I would put any of them on my car.
Old Aug 11, 2010 | 08:03 PM
Kevlo911's Avatar
Kevlo for President
Yea I know that, that's why I've been looking at Gorilla lugs and Mcgard
http://www.summitracing.com/parts/GOR-21132ET/ (I have 4 Gorilla wheel locks so I won't need 20 lugs total)
Might get those. It looks like it will catch a good amount of threads like the current hex lugs I have right now do
Old Aug 12, 2010 | 02:34 AM
1hawaii50's Avatar
How can the tuner lug catch twice as many threads as the stock lugs? My stock lugs actually seated close to 1-2 threads deeper than my Kics Projects. If you have a spacer on the car, then you only have so many threads available, no matter which lugs you use. You're safest bet here is to get some extended studs, and go from there.
Old Aug 12, 2010 | 06:22 AM
Kevlo911's Avatar
Kevlo for President
I dunno, the stock acorns don't catch as many threads on my wheel. I will try to get some pics today to show why. Yes, I know ultimately I need longer studs. But I don't have the time right now and my tuner lugs work fine but I hate the HEX tool and it is starting to strip.
Old Aug 12, 2010 | 12:58 PM
Kevlo911's Avatar
Kevlo for President
I believe the hex part of the lug catches the rim thus not allowing it to catch as many threads. Since the tuner lug is slimmer, it gets in further (that's what she said )
Old Aug 12, 2010 | 01:52 PM
1hawaii50's Avatar
The hex part SHOULD NOT be catching on the rim. Both are a 60 degree taper, so even if the "hat" on one of the lugs is wider, they should both seat the same depth into the rim...60 degrees is 60 degrees no matter how far the taper runs up the length of the lug. You may think the tuner lug is catching more threads, but I don't believe it could be.
Old Aug 14, 2010 | 06:38 AM
Flava_24/7's Avatar
Boosted Panda
I like my gorilla lug nuts, But for the set I believe they were around 30 bux. Discount tire acutally carries them in stock. The have the closed end and even the open end and all take the gorilla key.
Old Aug 31, 2010 | 02:13 PM
ThaBigGreek's Avatar
i have a quick noobie question, while putting a lug back on my car after painting some calipers i stripped the inside of the lug and the outside of the screw, i bought i new lug but what do i do now???
Old Aug 31, 2010 | 02:23 PM
1hawaii50's Avatar
By the "outside of the screw", I'm guessing you mean that you stripped the stud? If so, you will need to replace it.
Old Aug 31, 2010 | 02:24 PM
yea the stud, sorry about being so vague, but what do i have to do to replace it? do they just sell em?
Apr 16, 2020 05:15 AM
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
knight_yyz
Nov 1, 2015 01:34 PM
Redfox
Sep 28, 2015 10:41 AM
