Will this wheel size fit my 4th Gen A32 Maxima?
Old Aug 27, 2011 | 01:21 AM
Ceasars Chariot's Avatar
Old Maxima Legend
Stud pattern: 5 Stud x 114.3 PCD ~ 72mm centre bore
Rim size: 17 inch x 8.5 Offset ET 30+
Is this enough info or do I need anthing else from the seller ?
cheers
Old Aug 27, 2011 | 12:45 PM
That should fit just fine. I'd look into getting some hub rings since the center bore is larger.
Lakersallday24
Nov 7, 2024 07:31 PM
CRizz
41
Jun 7, 2021 05:42 AM
HOKUSMAX
Nov 13, 2017 04:34 AM
morteljc
Oct 19, 2015 10:47 AM
