g35 18s rubbing
Old 05-13-2012, 07:31 PM
tseng1023's Avatar
g35 18s rubbing
Will going from 245 to 225 in the rear stop the rubbiing?
tseng1023 is offline
Old 05-14-2012, 08:50 PM
036mtmax's Avatar
Im dropped less then a 1 finger gap on G coupes with 225/45's and 20mm spacer's in the rear and i only rub with passengers over big dips. Without spacers your ideal size would be 235/40 though.
036mtmax is offline
Old 05-15-2012, 05:47 AM
Snypa's Avatar
235/40 + 15mm spacers + partially rolled fenders + 2" drop = No Rub !!
Snypa is offline
Old 05-15-2012, 05:48 AM
DaRookie202's Avatar
225/40 would eliminate the rubbing
DaRookie202 is offline
coolsun
Wheels/Tires
11-13-2016 05:01 PM
thatcollegestudent
18
10-05-2015 02:29 PM
Serotta33
09-17-2015 12:14 PM
thenewguyy
09-12-2015 11:12 AM
Quick Reply: g35 18s rubbing
