Winter Meats!
Old Sep 22, 2012 | 08:31 PM
CauzinDrama's Avatar
Winter Meats!
Ok so I have some 205/55/16 Snow tires that I used with my 626. I was wondering if I could use those on my 2002 Maxima?
Im currently running 225/50/17. I know Id have to get some Steel wheels for them as the only 16" wheels I have are Enkei RS6's. But if all else fails Im pretty sure those wheels will fit the Maxima.
Old Oct 4, 2012 | 12:44 PM
Anyone?
Old Oct 4, 2012 | 12:51 PM
Amerikaner83's Avatar
well, find out if the bolt pattern of the 626 is the same as the max. 205-55-16 tires will work fine.
edit - what is your question? You ask if those tires will fit a wheel, but a wheel you don't have?
Old Oct 4, 2012 | 05:46 PM
Snypa's Avatar
if ref'ing to mazda 626...i think the newer ones have same bolt pattern as us
Old Oct 17, 2012 | 03:05 PM
My main worry is if the 205/55/16 will work without messing up the ABS.... so if that's good then I will just mourn those in my enkei wheels and ill have a decent set of snow tires.... because 225/50/17 snows aren't cheap.
mclasser
22
Nov 12, 2020 01:58 PM
240tomax
Tires and Wheels
Feb 10, 2016 11:01 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
Serotta33
Sep 17, 2015 12:14 PM
