Wheels with low offset and larger rear width for 5th Gen
Old 06-29-2015, 07:52 AM
TheMafia's Avatar
Ive been looking and looking for rims for the last week or so now and its making me ask a lot of questions i cant answer since im kinda new to the rim situation.
I have a wish list, perhaps some ppl can help me if i post it here.
Wish list:
-18"
-concave rims
-rims which have spokes that end literally at the edge of the rim (no additional outer perimeter)
-front 8.5 to 9??
-rear 9+
-front low offset, wide stance
-rear even lower offset to avoid spacers but good stance
-would love to find a rim that i dont need spacers for, using low offset
Samples similar to what i like:
Design + concave: http://www.tsw.com/alloy_wheels_max.php
Spokes to edge + concave: http://www.discountedwheelwarehouse....%2Es&pID=78829
Rear deeper than front (made for rear wheel drive car???): https://maxima.org/forums/5th-genera...ml#post9056229
Questions:
-is 9" or 9.5" on the front too much for 2002 nissan maxima?
-how do i find rims that have different widths for rear/front wheels?
-what are some other wheel databases out there where i can select dimensions and see a list of all manufacturers other than the following?
http://www.discountedwheelwarehouse.com/
http://www.mostwheels.com/
-should i go 19"??
TheMafia is offline
Old 06-29-2015, 09:22 AM
Y2kMaxima's Avatar
I can help a bit. 9 in front is completely fine, just make sure you run the right tires or you will have rubbing issues. Like 235/40/18 up front if you want a little stretch. I'd get like a +20 or +25 offset wheel for the front. That would look great. It all depends what tire size you get man, like I had told you I want to run the 370z rears up front with the +15 offset. I would run 235/40/18 and have no rubbing.
19's are too much. Too big, too much money, tires are too damn expensive.
Y2kMaxima is offline
Old 06-29-2015, 09:25 AM
TheMafia's Avatar
Thanks, and what about 9.5?
TheMafia is offline
Old 06-29-2015, 09:28 AM
Y2kMaxima's Avatar
9.5 is fine it just depends what your offset is man. It may be too wide if you have a low offset.
Old 06-29-2015, 09:53 AM
TheMafia's Avatar
ah ok, noted.
my concern was internal bumpage... i dont want to full turn and have the wheel rubbing into the wheel well or other parts
TheMafia is offline
Old 06-29-2015, 10:16 AM
Y2kMaxima's Avatar
ah ok, noted.
All depends on tire size man
Old 06-29-2015, 11:48 AM
TheMafia's Avatar
and thats dependent on wheel width.... i will maintain the same rolling diameter with the rims i choose.
TheMafia is offline
Old 07-06-2015, 08:49 AM
TheMafia's Avatar
im looking at getting 4x XXR 530's
18x9.75" +20mm off set
will that be an issue up front?
was considering 5mm spacers too
TheMafia is offline
Old 07-13-2015, 07:16 AM
TheMafia's Avatar
has anyone put on 9.75" up front?
TheMafia is offline
Old 07-20-2015, 08:13 AM
TheMafia's Avatar
im nearly 100% convinced that i should get the following setup:
XXR 530 Hyper Silver (my car is dark gray luster)
Front: 18"x8.75" +20mm
Back: 18"x9.75" +20mm
Just hoping the back will now be plush with the fender and look like its staggered
Price in CAD: ~$1000 (rims only)
TheMafia is offline
Old 07-20-2015, 08:16 AM
TheMafia's Avatar
or should i go
Front: 9.75" but with +30mm offset
Back: 9.75" +20mm
this way i get all the grip i want up front, and might still get a nice staggered look
TheMafia is offline
Old 07-20-2015, 08:19 AM
I'd stagger offset for sure since you're not staggering width.
ChrisMan287 is offline
Old 07-20-2015, 12:46 PM
TheMafia's Avatar
i wasnt able to find +30mm for those...
so it looks like 8.57" +20mm up front
TheMafia is offline
Old 08-02-2015, 04:18 PM
cheftoo's Avatar
What's the purpose of having offset when you have fwd. won't it create more wear on the rear?
cheftoo is offline
Old 08-04-2015, 07:02 AM
TheMafia's Avatar
it shouldnt actually, if you have +0 offset, then the lug nuts attach to the wheel in the center of the rims, this can actually add balance in my eyes.
TheMafia is offline
Old 08-04-2015, 12:03 PM
cheftoo's Avatar
So I can't put 8.5 on front and 9.5 on the rear with no issue as long as the offset is 0? Is that correct?
cheftoo is offline
Old 08-04-2015, 01:01 PM
TheMafia's Avatar
best do more research than that, there is a thread:
https://maxima.org/forums/tires-whee...-will-fit.html
also, im told that 9 up front isnt a problem, maybe even 10??
TheMafia is offline
Finkle
09-27-2015 09:53 PM
Huttig2009
09-25-2015 03:31 PM
MaximaDrvr
08-19-2015 08:20 PM
twotonezed
08-16-2015 11:41 AM
RealityCheck
08-05-2015 06:18 AM
Quick Reply: Wheels with low offset and larger rear width for 5th Gen
