How to get rid of P0446
Old Sep 12, 2006 | 08:06 PM
alleydawg6's Avatar
Livin dreams thru his Maxima
is the code P0446 a dealer code? meaning can only the dealer clear it? I replaced the sensors the FSM points to be the problem but the code doesn't go away. any suggestions? Thank you
Old Sep 13, 2006 | 10:55 AM
alleydawg6's Avatar
no one has any suggestions?
Old Sep 13, 2006 | 11:57 AM
konak85's Avatar
What does the code say? did you reset the ecu after replacement?
Old Sep 13, 2006 | 05:45 PM
alleydawg6's Avatar
yea i did ... it just keeps coming back even though i replaced the sensors
Old Sep 13, 2006 | 06:26 PM
jasonv's Avatar
what exactly is the code?
Old Sep 13, 2006 | 09:57 PM
alleydawg6's Avatar
the code is P0446 which translates to 0903 ... the FSM says it's for Evaporative Emission Canister Vent Control Valve. I changed the valve and I also changed the pressure sensor(boost sensor) ... after this I reset the ECU using a OBDII scanner ... but the damn code keeps coming back
Old Sep 14, 2006 | 08:29 PM
jasonv's Avatar
check the lines going to the valve. you might have a leak
Old Sep 14, 2006 | 09:27 PM
alleydawg6's Avatar
u know now that u mention that ... I do hear a hissing sound when driving next to parked cars at a slow speed ... I'll check on that and post back ... thanx alot
Ali
Old Sep 16, 2006 | 10:31 PM
adithius's Avatar
You probably have a small leak in the Cannister. The system is not pressurizing, and the cannister will need to be replaced. Also blow out any potential charcol from the hoses.
Old Sep 16, 2006 | 11:31 PM
alleydawg6's Avatar
I think ur right ... thanx alot man
Old Sep 17, 2006 | 02:07 AM
WielkiWaac's Avatar
MaximaDriver
Like This Guy Said.
You Must Have A Leak Somewhere In Evap Systam
Old Sep 17, 2006 | 05:46 AM
pkchoban's Avatar
96 maxima's have a recall out from a while ago for this...it prevented passing inspections because of the light...not sure if your car has had it done yet, but its free and its done by the dealer...I believe the campaign id was PNC P8132...if you call the dealer can look it up and find out for you....i had the same thing but my plug into the canister was broken once i fixed that it never came back
bryants95max
Oct 2, 2015 12:52 PM
worldwiderecognized
Sep 24, 2015 06:56 PM
maxima297
Sep 24, 2015 10:31 AM
Nv2dmaxmd
Sep 23, 2015 02:12 PM
homewrecker
Sep 23, 2015 03:41 AM
