How to change front turn signal bulb?
Old Jan 30, 2012 | 04:54 PM
JEFF6898's Avatar
OK I know I am missing something here. Need to replace left front turn signal bulb. I see no way at all to get to it from under the hood and I don't see any screws to take off the lens to get to the bulb. So what am I missing? How do I change it?
Old Jan 30, 2012 | 04:55 PM
95Maxed's Avatar
Flat head screw driver, pop the physical turn signal out of place. One of them will pop out, then you unscrew the other. Then change the bulb.
Old Jan 30, 2012 | 05:24 PM
luke95gxe's Avatar
flat head screwdriver pop out the side marker light then u will see a philips head screw un screw an remove
Old Jan 31, 2012 | 02:15 AM
2brosgixxer's Avatar
Old Jan 31, 2012 | 02:23 AM
max ride 41's Avatar
omg, r u serious??? fricking search, easy as pie man, damn...
Old Jan 31, 2012 | 02:28 AM
Agree..sort of...No search necessary, just look at the damn thing and with even a little bit of car knowledge, you should be able to figure it out. Ah well, I'm bored so i'll help the guy out.
Old Jan 31, 2012 | 09:04 AM
95Maxed's Avatar
We were all there once, it took me 10 seconds to explain to him how todo it... get over it.
Old Jan 31, 2012 | 06:09 PM
JEFF6898's Avatar
Darn thought this was a forum to help people not put them down. Guess some people are just so damn smart they think everyone should know the answer.
Old Jan 31, 2012 | 06:25 PM
tigersharkdude's Avatar
^^You should try to SEARCH before asking questions.
Old Jan 31, 2012 | 06:56 PM
wirelessdude04's Avatar
Get a FSM it has everything in it and it's free
Old Jan 31, 2012 | 07:18 PM
I fail to see where no one helped you. IIR the first 3 or 4 posts gave you the answer, including a pic. So why not try thanking us for helping?
Old Jan 31, 2012 | 09:04 PM
Here's how I do it to avoid the risk of chipping/damaging the plastic housing. Lay on your back, undo 3 screws holding the underliner tray, reach up and get access to the bulb.
HOKUSMAX
Nov 13, 2017 04:34 AM
homeyclaus
Sep 3, 2015 06:15 PM
Balkins
Aug 12, 2015 06:39 AM
RealityCheck
Aug 5, 2015 06:18 AM
maxima297
Aug 3, 2015 12:50 PM
