Need a second opinion for suspension problem
#43
I think it's that too since it's only with gas pushed. What kind of axles can handle a car with it very low? It wasn't too low but low enough to bottom out while going up on a driveway if I drive straight in only. I think axles I got in there are autozone ones
#45
"These people" are people to avoid lol. They can be done in an hour, easily, if you know what youre doing. Two or three per if youre going in completely blind. Maybe in bizarro universe control arms would run you 800+ but certainly not here.
However you should be starting with that single nut like asand1 said. Its just a nut. A monkey could do it. Start with the little things and work your way up from there, you dont even know if the control arms need to be replaced.
#46
Just an update for my similar problem...
I had both axles replaced over the weekend and that solved the knocking noise issue. Unfortunately, it appears one (or both) of the axles is defective so I have a vibration when accelerating in 2nd gear from 2-2.5k RPM now. These axles were from AdvancedAuto. One box came pretty beat up with some minor damage to the dust boot and spline on one box. Had them install it anyway, so that may be the reason for the vibration. I contacted Raxles before ordering the AZ ones and they did not offer them anymore.
edit: thought they were from Autozone , but they were from AdvancedAuto.
#47
I checked and took apart my lowering springs from strut and found out that the right side the man didn't put my strut bearing. Idk where that bearing is. The left side had the bearing. Still money is on axles? It's during acceleration only though when doing left turns and noise from right side and that's the side without the bearing
dvcamp
09-18-2015 10:17 AM
ag90fox
09-09-2015 12:22 PM
Violator
09-09-2015 10:14 AM
