Can I replace fuel filter?
Old 09-14-2015, 11:37 PM
bumpypickle's Avatar
So I have my stock intake, iacv, and throttle body off of my 97 5mt because I'm cleaning them all. I plan on doing the egr valve, temp sensor, pcv valve and sparkplugs while everything is out, but right now those three parts are off my engine. I ordered a puralator fuel filter and didn't expect to get it this fast and already have these parts off my car so it would be nice to be able to change that while they're all off.
My question is, with those parts off (stock air box, iacv,throttle body, &corresponding electircal connectors/coolant hose, can I safely remove the fuel pump fuse and relieve fuel pressure to change out the fuel filter w/o damaging anything? The last time I changed a fuel filter on my 97 auto, I believe those said parts were attatched, well at least the iacv and throtle body that is.
bumpypickle is offline
Old 09-15-2015, 05:04 AM
Turbobink's Avatar
In reality I'm thinking you can, but I'm also thinking of a few reasons why you shouldn't.
If it were me, I'd wait until things got put back together.
Turbobink is offline
Old 09-15-2015, 10:35 AM
M in KC's Avatar
Ahh, put two hemostats on the flexible fuel hose and replace the filter. You should have a pretty straight shot at it with all that removed. I've never pulled the fuel pump fuse and bled the pressure off the system when I've changed mine. You're gonna dribble a small amount of fuel out of the filter either way.
M in KC is offline
Old 09-15-2015, 02:09 PM
Half Assed's Avatar
It's going to leak whether you pull the fuse or not. I'd be more worried about getting fuel shot in my eyes than all over the engine bay. It will easier to access with those parts removed and the fuel spray will evaporate by the time you get the other stuff back on.
Half Assed is offline
Old 09-15-2015, 04:26 PM
Daniel VQ30life's Avatar
No need to remove fuse, gas losses will be unnoticeable, not even an 8 oz glass will leak out, but now is a good time to do it, its not exactly fun with everything in the way
Daniel VQ30life is offline
Old 09-15-2015, 08:49 PM
ef9
ef9's Avatar
I prefer to pull the fuse and run the car till it dies. I had fuel spray in my face when doing otherwise.
ef9 is offline
Old 09-15-2015, 09:27 PM
I wouldn't worry about pulling the fuse. I've pulled the fuse and not pulled the fuse...the difference is negligible if the car has sat for a while.
The Wizard is offline
Old 09-16-2015, 06:59 AM
cashoit's Avatar
i wdnt start the car the with all those parts removed. just drain the fuel to a bucket if anything.
cashoit is offline
Old 09-18-2015, 07:05 PM
Thanks for the reply guys I know how to relieve fuel pressure just wanted to know if it's safe to do it with intake off.
Old 09-19-2015, 06:28 PM
You didn't remove the lower hose first?
Old 09-20-2015, 08:22 AM
maximaham's Avatar
man just wrap it with towels pull the hoses replace and be done with.
maximaham is offline
00MAXI
09-02-2015 10:23 AM
305head
08-26-2015 09:03 PM
homewrecker
08-24-2015 08:56 PM
kirkhilles
08-08-2015 10:53 AM
maxima297
08-03-2015 12:50 PM
Quick Reply: Can I replace fuel filter?
