ae shift knob install
Old 09-15-2015, 01:40 PM
2kmaximel's Avatar
ae shift **** install
can anyone help with what needs to be done to install the AE automatic shift ****. the things i have found no pics or detailed information on what exactly needs to be done. i have a 2000 maxima and would like to know what is needed to be done to the existing parts. any help would be great. thanks
2kmaximel is offline
Old 09-16-2015, 01:51 PM
2kmaximel's Avatar
over 100 views and not one answer to help? im sure someone out there can help right???
Old 09-16-2015, 02:07 PM
Do you already have the ****? If you do, it should be extremely straight foward.
Remove screws, cut O/D wiring, pull up on ****, install new **** and splice O/D wiring.
ChrisMan287 is offline
Old 09-16-2015, 02:35 PM
2kmaximel's Avatar
i should be getting one shortly and i did a search and members were talking about modifying the factory plastic and cannot go back to the original t-shaped version after so i was curious as to the modification. i guess i will figure it out when i receive it. thanks for the reply.
Old 09-16-2015, 03:15 PM
fat_kid's Avatar
Found in the installation stickies: https://maxima.org/forums/5th-genera...00-se-how.html
fat_kid is offline
Old 09-16-2015, 03:19 PM
2kmaximel's Avatar
thank bro. i have seen that but it does not explain the modifications. and his link does not work.
i will figure it out and post what needs to be done so if others need to know it will be here.
03-12-2020 12:06 AM
MaxLife17
06-27-2019 01:37 PM
bryants95max
10-02-2015 12:52 PM
lowpost99
09-08-2015 05:06 AM
Johnny9595
09-03-2015 05:18 AM
Quick Reply: ae shift knob install
