radio doesn't store presets
Old 09-08-2006, 07:23 PM
craigl33's Avatar
when i turn the car off it doesn't save the presets. also when i start the engine the cd pops out automatically. also the radio antenna doesn't go up. doesn't even make a motor sound. i know it's pretty vague, but maybe someone can help me isolate the problem.
craigl33 is offline
Old 09-08-2006, 07:27 PM
Suspension Yoda
djfrestyl's Avatar
Your problem is isolated to this:
It is not wired correctly.
djfrestyl is offline
Old 09-08-2006, 07:32 PM
NineOhSE's Avatar
further isolaton
It seems your constant power wire isnt wired correctly to constant power....
NineOhSE is offline
Old 09-08-2006, 07:34 PM
Suspension Yoda
djfrestyl's Avatar
Also, your power antenna wire is not connected to the power antenna lead.
tastey wheat
mendon99's Avatar
lol wired completely wrong. black should be to ground, yellow should be to constant, red should be to ignition. blue should be power ant, blue with white tracer should be remote if you need it.. and the rest aside from dimmer/illumination and maybe mute, should be speakers.
in fact, it should be color for color if you bought a harness, how did you hook it up?
mendon99 is offline
Old 09-08-2006, 09:30 PM
craigl33's Avatar
forgot to mention it's the bose system. 96 model. it's kind of hard to not wire it correctly when it's using harnesses. no wires to connect.
craigl33 is offline
Old 09-09-2006, 05:32 AM
BLK2BLU's Avatar
Maybe a wire got cut, or there is a short
BLK2BLU is offline
Old 09-09-2006, 06:11 AM
Suspension Yoda
djfrestyl's Avatar
Although this shouldn't matter, what year is your car?
Old 09-11-2006, 02:56 PM
craigl33's Avatar
96. i'm surprised no one said fuse. fuse went out.
craigl33 is offline
Old 09-11-2006, 04:01 PM
Suspension Yoda
djfrestyl's Avatar
Because we all thought you were using an aftermarket HU.
gavin68
09-18-2021 12:36 PM
chisam14
11-06-2018 08:56 PM
BobTX10
10-07-2015 08:43 AM
Max Nu-BE
09-28-2015 10:25 AM
Quick Reply: radio doesn't store presets
