Power Window Problems
Old 03-16-2015, 01:30 PM
ChimChark's Avatar
Hey everyone, I'm new here and was looking for some help. So i have an 02 Maxima whose windows have been working great since last summer. Then this winter, only the driver side window will work. The other windows will not roll down from the Master switch or from the switches on their respective door panels. I've checked the fuses and they aren't blown. I've also taken off the door panel and looked at the wires, nothing was touching metal and the wires were covered properly. I should also mention that the lock button on the passenger door stopped working too. Again, it seems none of the windows work other than the driver door. Everything else electronically is working fine/ Hope this is an easy fix, if you need anymore information let me know. I'm new at this kind of stuff.
ChimChark is offline
Old 06-10-2017, 07:37 AM
Kniffen22's Avatar
I'm also having the same problem have you figured anything out?
Kniffen22 is offline
The Frye
09-02-2021 11:03 AM
lowpost99
05-16-2021 11:18 AM
The Frye
02-03-2019 08:34 AM
trungg86
09-04-2015 04:58 AM
Quick Reply: Power Window Problems
